ive got a friends dm500c that had a bad flash (probably clone) tried to connect with null modem cable to dreamup, dreamup finds the box says Dreambox 500c but after that theres never any progress, so i assumed there was a problem and i need to jtag it, jtag was successful or it will flash the device 100%, i tried dreamup again with the same problem shows box but just stops. i then logged into hyperterminal and watched the boot process and this is what i get
Is this good or bad ??? also i cant send any commands to the dreambox from hyperterminal(not sure if im suppose to be able to) i can type but enter appears to do nothing(faulty null cable??)
Can anyone give me some tips on what i can do from here
also thanks to everyone on here for posting so i have got as far as i have
Unable to read configuration data
--- Device Configuration ---
Power-On Test Devices:
000 Enabled System Memory [RAM]
Boot Sources:
001 Enabled Application in Flash [FLASH]
002 Enabled Ethernet [ENET]
local=0.0.0.0 remote=255.255.255.255 hwaddr=000934125485
003 Disabled Serial Port 1 [S1]
Baud = 9600
Automatic Boot: Enabled
1 - Toggle Power-On Tests
2 - Change a Boot Device
3 - Change IP Addresses
4 - Ping test
5 - Change Baud Rate for S1 Boot
D - Display Configuration
0 - Exit Menu and Boot Application
Boot Sources:
Baud = 9600
4 - Ping test
