Best image for DM500C
  • mols0n
    • 118
    DM500 Best image for DM500C
    What would you suggest is the best all round image and cam for the DM500C. I am currently using Gemini 4.4 with 2.12 Evocam and works fine apart from the occasional freezing and unable to get s** box office and the xxx channels.
    What would you recommend to flash it with?
    Many Thanks.
  • cgscott
    • 3513
    I recommend dk1.1. It downloadable here.
    Digital Kaos - Downloads - Images
    Excellent skin and addon features.
    Patience is a virtue.
    • Devilfish
      Administrator
      • Feb 2008
      • 7872
      I would also recommend the DK v1.1 image.
      I always use evocamd_2.12 as I think this is the best emu.
      • mols0n
        • 118
        Hi
        Would you use DreamUp or FlashWizard Pro to install the new image.The reason why I ask is that I've tried to flash the Neutrino and Kos1 images in the past using DreamUp and getting the "flash successful" when I boot up the box back up again the screen is just black and nothing happens-not even the remote. Only when I reflash my backed up image with DreamUp does the box work? I have also tried the same with thing using FlashWizard Pro but it stops working 3/4 of the way through and seems to stop doing anything even after a couple of hours the image hasn't loaded. Any ideas/advice would be appreciated.
        • Devilfish
          Administrator
          • Feb 2008
          • 7872
          Dreamup 99 times out of 100 works for me.
          I usually ftp the img file to the /tmp folder and flash it using a telnet command (sticky threads).
          I would never use FWP.
          • mols0n
            • 118
            Ok thanks for that I'll give that a try. Does the Kos1 image pick up the s** box office and xxx channels on a scan?
            • Devilfish
              Administrator
              • Feb 2008
              • 7872
              All enigma images won't scan in the extra ~~~~ and sky box office channels.
              See here for the info needed to add them in.
              • mols0n
                • 118
                OK thanks for all your advice.Great site with excellent info.I'll give all this a go later.
                • Devilfish
                  Administrator
                  • Feb 2008
                  • 7872
                  Glad we were able to help you out!
                  • hutchy
                    • 5
                    i own a db500s and use cccam, but i dont get sxxbox office. is this just for cable boxes or am i missing a trick to get the box office channels open?
                    • Curious123
                      • 2591
                      This is available on satellite but you would need cardsharing to access any of the S*y channels without a subscription.
                      • efcevo
                        • 67
                        many thanks
                        ive been looking for days for a new image for my dm 500 hopefully this will work i live in the uk and use cable think iwill have to put some cams on my d box not sure hoe to do that yet any help woul be welcome!!!
                        • aong2211
                          • Apr 2009
                          DM500C Image download
                          Hi,
                          Try to download the DKv1.1 image ..
                          Will you allow me to?
                          • juicebox
                            • Apr 2009
                            promblem with dreambox 500c
                            hey i recently bought a dm500c from in england but now i've returned to barbados and try turning it on it's just showing a black and white screen with digital-kaos.co.uk on it, its also saying no EPG available, im using a 4th generation card, can anyone help me here ?
                            • bigbaz123
                              Great
                              Brillaint All Works Perfect
