500c, how to increase/decrease sharpness ??
  • Saltire
    • 1361
    Is there a way to adjust the picture output sharpness of the dreambox 500c ?
    I have the DW 2.1 image at present.
    Hope someone can help me with this as its doing my head in, thanks.
  • tomhick024
    • 559
    Don't think I have ever came across info/posts to increase picture quality, would be news to be if there was some hardware changes you could make.
    If you have tried diff setting in 'AV setup' maybe try the video/audio leads instead of using the scart lead!
    That's all I can suggest to ya.
    Best of luck!!
    Whatever!!
    • Saltire
      • 1361
      Best of luck!!
      video/audio leads ? please advise.
      I thought scart was as good as it gets apart from hdmi cables ?
      • tomhick024
        • 559
        Use the component outputs, ie yellow, red and white output connections that are alongside the scart output, cable would have came with your dreambox from new!
        Lots say it sorted their poor picture quality when using a scart lead! Its surely worth a try anyway!
        Whatever!!
        • Saltire
          • 1361
          so component is the one that have 3 cables, right ??
          do they carry sound too or is it just video ?
          • tomhick024
            • 559
            one is video, other two are sound -left/right.
            Whatever!!
            • Saltire
              • 1361
              is component meant to be better then scart then ?
              • Saltire
                • 1361
                cheers jok, i wasnt sure about component or composite as ive never tried any of them, oh well, back to scart then,
                • mjrrenegade
                  • 49
                  My dreambox was a bit fuzzy until i bought a decent quality scart cable. Got a shielded gold plated one for about ?5. Made a big difference!
                  • tomhick024
                    • 559
                    Originally posted by JoK
                    You dont have component on your box, you have composite
                    Yellow=video
                    White and Red= sound
                    Scart is better than composite, component is better than scart.
                    Stick to scart in this case, check leads and av settings in box.
                    JoK
                    Sorry mate, got desc. wrong!
                    Using video/audio leads, some say it was better than scart.
                    Some cheaper scart leads have only bout 5-6 pins on their connections, but good quality one have full 20 pins out!
                    Dont know what diiference it would make but is something you could check out a little further!
                    Whatever!!
                    • Saltire
                      • 1361
                      i'm using cables that cost me about 30quid a piece, so they will be ok,
                      • Saltire
                        • 1361
                        This is doing my NUT in , it works absolutley perfect and crystal clear on my other 6 year old plasma, yet on this brand new one it gives like a very slight out of focus picture, some things look ok, and some dont, most of the latter , i even double checked the box was ok by attaching it to the old plasma and its pefectly fine.
                        And i also plugged in my real virgin cable box (standard def) to check what kind of picture that gives and its a lot clearer than the dreambox, hmmmmm ????????? me not happy
                        How can this be and it works ok on the other telly ??
                        • Saltire
                          • 1361
                          could using another image perhaps fix this problem ???
