Hi all,
Have finally got my 500C working with Kaos v1.1 image with all relevant keys and Picons. I'm now facing the following problem:
I'm using DreamBoxedit 2.02 to download default Bouquets to local PC to edit and upload back. Did the downloading from Dreambox successfully a few hours ago and started to edit them.
I then came to uploading revised bouquets and tried the ftp connection within the DreamBoxedit app. Now for some reason it won't connect. I cant see the network connection as active in the router either.
I have checked the following:
Application:
1) FTP Settings in Dreamboxedit are OK.
DreamBox:
1) Network is enabled and on dhcp
2) Rebooted Dream box, hard and soft.
3) Disabled network, rebooted, enabled network, rebooted.
4) On router DHCP settings I also enabled 'use same IP address' for the dreambox device.
Cabling:
Checked all cables. All fine.
It seems like the Netwok connection on the dreambox is dead> Any ideas pls ?
Booya16
Application:
DreamBox:
Cabling:
Booya16
