Can anyone help??
Flashing Problems With My Dm7025,
Have a look at this thread as it seems someone is having the same problem as yourself.
Does flashing the DB7025 over HTTP not work? - Sat Industry ForumsComment
just a thought can you use a yellow video lead from the back of unit to the tv
and change your video setting on the dream box if you can see a picture
or different scart lead
or any chance of sending it back if under garantee
have you got a proper null modem cable and dream up if not it wont flash also make sure you have an nfi image use this gemini one it works for me i have a 7025
RapidShare: Easy FilehostingComment
Hi.
I have same problem with DM800hd.
I cannot flash anything , it just seems to freeze when it gets to the stage of "box flashing from it's memory"
I am going to try the erase.zip file.
Strange though, i think it has something to do with the size of the file, as i was able to load on bootloader70 but that is only a small file.
cheersComment
dont discount a duff psu. Mine had weird problems - turning my tv back to cable when on xbox, blank screens evry 10 secs when recording diff channel, trouble booting - replaced the psu and alls fine.
try disconnecting the hard drive (ie lower power required) and see if probs still exist...Comment
