Green screen!!!!
  • vocalis
    • 25
    DM500 Green screen!!!!
    Hello
    My 500C has just started behaving erratically.
    When on, the TV screen goes completely green (although you can still watch the channel)!
    I know it is a problem with the scart connector as I had the same problem with another 500C and Buyingthings kindly replaced it with this one.
    No problems until I had to remove the scart to flash a new image and started getting green screens once reconnected.
    Initially I could fix it by adjusting the position of the scart a little at the back but now green all the time!
    I have been emailing Buyingthings for 2 days but no reply as yet.
    Concerned it is a faulty batch.
    Any advice?
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    Go to Menu > Setup > System Settings > A/V Settings.
    Adjuste the video settings and see if it brings it back. It might be that your image is set for component video (YUV).
    • ZaFoD
      • 43
      You could also try a new/different SCART lead.
      The solder joints in them can oxide's easily while in use, then they can fail when moved around.
      • shady77
        • 982
        .....or use component cable for a temporary fix
        • jbvid
          • 261
          @vocalisi
          Hi
          Very good idea there from shady77, if you don't cure it with a new scart lead and trying it on another TV then it could be the scart socket motherboard connections inside the 500c and trying/using the component (RCA Phono) output would eliminate a scart output fault.
          jbvid
          • vocalis
            • 25
            Thanks everybody for your excellent suggestions.
            I am going to try them all this evening and will post a reply to let you know.
            Thanks again.
            Great forum!!!
            • vocalis
              • 25
              Update!
              I followed Devilfish's excellent suggestion and changed the A/V settings.
              Although it wasn't set for component video, adjusting the settings seems to have sorted out the problem and I haven't had problems since!
              Thanks to everybody!
              • Devilfish
                Administrator
                • Feb 2008
                • 7872
                Nice one vocalis, glad you managed to sort it!
                • vocalis
                  • 25
                  Thanks to you Devilfish!
                  Your replies are always spot on!
                  Cheers
