dreambox image
  • pudzy
    • 206
    dreambox image
    evening or morning.. im looking for image for dreambox 500t (clone) i will be needing one that allows mee to add new cams. ie , newcamd , cccam, newdcs. any help i e grateful.
  • mini
    • 602
    just have a look in download section mate.
    • pudzy
      • 206
      can newcamd be used on dk_2 image.
      • tomhick024
        • 559
        You should be able to add any cam you want to any image, if not on their server, just add it manually!
        Whatever!!
        • pudzy
          • 206
          when ftp newcamd to dreambox what file do you install it 2.. also do you have to unzip file first and transfer all newcamd files one by one
          • red devil
            • Oct 2008
            • 690
            ftp complete file to tmp folder and do a manual install via menu using remote
            or why not just download from the server if box is connected to router
            • pudzy
              • 206
              ok, the darkstar 11 image has all the cams , can i use this image on mmds with rom 10 card, sorry if this sounds stupid.
              • red devil
                • Oct 2008
                • 690
                yes you can, you need newcamd 6.10b or some peeps use 5.28 i think but why bother mmds is gone in a few weeks, get yourself a sat box and a sky card if you want to use a dreambox instead of a subbed box
                • pudzy
                  • 206
                  i no m8, but just doing this to get feel for the dreambox.
                  • pudzy
                    • 206
                    can anyone give me run down on how to install newcamd 6.10 or where is there a guide on it somewhere,, thanks
                    • red devil
                      • Oct 2008
                      • 690
                      her you go, ftp it to the temp folder and do a manual install
                      when youve got that far give a shout back and we'll continue
                      • pudzy
                        • 206
                        i gave it quick run tru ,, i loaded to folder tmp then try to install manually but no joy. wouldnt install. i quickly ftp all the file to box using flashfxp .. but only 4 channells rte 1,2,3,4.... and only rte 1 working.. any idea ..
                        • red devil
                          • Oct 2008
                          • 690
                          you have a little bit more work to do than just stick in the card
                          is newcamd showing as an option when you press the blue button ?
                          and do you have the bk from the card ?
                          • pudzy
                            • 206
                            i give you run down... downloaded newcamd 6.10b, ftp
                            a. newcamd
                            Keys directory: /var/scce -keylist, ppua, rsakeylist & tpscrypt
                            Program files: /var/bin - newcamd, cardserv, cardspider, betadserv
                            Config files: /var/tuxbox/config - newcamd.conf, cardserv.cfg, betad.cfg
                            AU files: /var/scce/ - nagrarom3.bin, nagraram3.bin, nagraepr3.bin, sttestrom3.bin, stmaprom3.bin, nagrarom7.bin, nagraram7.bin, nagraepr7.bin, nagrarom10.bin, nagraram10.bin, nagraepr10.bin, nagrarom11.bin, nagraram11.bin, nagraepr11.bin, rsakeylist I put boxkey in config file ,, rebooted what else not much info on threads..
                            • red devil
                              • Oct 2008
                              • 690
                              is newcamd showing as an option when you press the blue button ???
                              and do you have the bk from the card ???
                              and btw what image is on the box now
