Bouquet files
  • Parisno
    • 80
    DM800 Bouquet files
    OK, after a bit of a struggle and more than a little help (Thanks everyone) I now have my DM800 all set up and running with an LT Fifth Campaign SP1 image just fine.
    After spending ages getting my bouquets set up just how I want them, it would be nice to back them up, however all the posts I can find on here point me to folders that dont exist or do not contain the correct files, so I guess they are different depending on Machine/image. Can anyone help out as to what files I should be backing up on a DM800 with LT 5th image?
  • westkill
    • 2378
    i have not got a dm800 but the same set up as my dm7025 nearly
    this should work
    if you have a internal hdd use the plugin backup and restore
    chose backup > etc/enigma2 and /hdd
    when you restore it may restore to a different skin
    so just change it back via menu>setup>system
    if you dont have an internal hdd
    ftp to your box
    goto etc/enigma2/
    transfer to your pc
    hope this works
    some times if you restore to a different image example: from pli to gemini dosent all ways work 100%
    • shazrab
      • Nov 2011
      That is always the case in any dreambox. There are a lot of files but you have to choose the right one otherwise it messes everything up and sometimes you have to reboot the whole system with a serial cable.
