Help Noob Setup DM500C Cam
  • superchipper
    • 9
    Please, i'm new to the dreambox DM500C, and after doing a lot of reading on past days , all i can do is watch FTA channels on my cable provider.
    My local cable provider uses NAGRA2, and i have a dump from the ROM110/AC3 local smartcard.
    I've installed DIGITAL KAOS 1.1 IMAGE, uploaded keys and scee folder thru FTP (from dreamboxstuff.rar) and hold INFO for 3 seconds and enabled EVOCAM. (I GUESS IT DIDNT WORKED HERE BECAUSE I NEED MY PROVIDER KEYS, NOT THE PROVIDED ON dreamboxstuff.rar, right ?)
    In the smartcard dump i see a lot of keys like for example "RSA Session Key, IKey ECM 00, IKey ECM 01, IKey Session Key, IKey Firma Session Key, BoxKey".
    My question is, wich of these i need to put on SoftCam.key and how i put it in there ? Just copy and paste ? Or do i need a specific format ? Can somebody give me any clues ? Somebody help me please.
    Thank's a lot
  • davemac82
    • 279
    BoxKey".
    Thank's a lot
    click on the link above follow instructions and that should be you.
    if you are using a smartcard with a dm500c you dont need 2 take it out and follow the steps again above and you should be sorted, to start evocam press the blue button on your remote and switch on evocam also if you tell us which area you are from it would maybe help
    • superchipper
      • 9
      I followed this link you posted when i installed the digital kaos image.
      Im from Brazil, my provider uses NAGRA 2 and the card has just been updated to REV AC6.
      I have a dump from the AC3.
      I can't even use my official card on dreambox, i put boxkey and rsa (n) i got from the AC3 dump, but NewCS gives me the following error:
      [ Box detect ] Box type 2 (Dream Multimedia (PPC) Box)
      [ Config ] Option <mhz> for device 0 (lower) not present, defaulting to 357
      [ Config ] /dev/sci0 ECM priority: round
      [ EMM Cache ] Initialising dynamic Cache
      [ ECM Cache ] Initialising dynamic Cache
      [ Loader ] Starting Telnet on port 3001
      [ Loader ] Reader type 5 on node /dev/sci0
      [ Sci ] Closing device /dev/sci0 [Handle=-1]
      [ Sci ] Opening device /dev/sci0
      [ ATR ] T=1 1etu=32.00us Guardtime:11etu CWT:139etu BWT:15371etu WWT:153600etu
      [ ATR ] Historical bytes: D N A S P 1 1 0 R e v A C 6
      [ Loader ] Init Nagra card
      [ Keyman ] Adding key 80382703 type 0 on Provider 000000 for caid 1800 ID=0
      [ Keyman ] Adding key 80382703 type 1 on Provider 003811 for caid 1801 ID=0
      [ Keyman ] Adding key 80382703 type 1 on Provider 003911 for caid 1801 ID=0
      [ Nagra ] DT$08 data not defined.
      [ Loader ] Card 1801 on port /dev/sci0 failed
      [ Loader ] Reinit card with caid 1801
      [ Sci ] Closing device /dev/sci0 [Handle=9]
      Last edited by superchipper; 14 September, 2008, 20:32. Reason: JUST UPDATED TO AC6
      • superchipper
        • 9
        Tried using CAMD3 with keys i got from AC3 dump
        Provider 3911
        DT 06 - RSA ECM (KEY DESENCRYPTED)
        9BF6AC31CE105EAF8D91E22DD67E5658757497979BFC03AFB3 0B7890316F9EC611E4C384B815FD5A796C178E8ED492D16A4A ED92368EFFD062BA18745DB44F55
        DT 06 - IKey ECM 00 (KEY DESENCRYPTED)
        9588476EC1C897F0195CD304A0A59666
        DT 06 - IKey ECM 01 (KEY DESENCRYPTED)
        D0E683269426687097059A7285E78EED
        Put these keys on camd3.keys :
        1801:003911:0000000000:B1:9BF6AC31CE105EAF8D91E22D D67E5658757497979BFC03AFB30B7890316F9EC611E4C384B8 15FD5A796C178E8ED492D16A4AED92368EFFD062BA18745DB4 4F55
        1801:003911:0000000000:E1:03
        1801:003911:0000000000:00:9588476EC1C897F0195CD304 A0A59666
        1801:003911:0000000000:010E683269426687097059A7285E78EED
        AND STILL CANNOT WATCH CHANNELS
        camd3: BOXTYPE: dm500
        camd3: LOG: 2
        camd3: UDP_PORT: 20248
        camd3: HTTP_PORT: 9080
        camd3: DNS_CACHE: 60 sec
        camd3: DESCR_DELAY: 0 ms
        camd3: camd3.map not found
        camd3: camd3.ignore not found
        camd3: /dev/dvb/card0/ca0 Device or resource busy
        camd3: UserDB(add): USER=benutzer1 PASS=password2 FROM=any SERVICES=all
        camd3: UserDB(add): USER=benutzer110 PASS=password10 FROM=any SERVICES=1702:000000:0008,1722:000000:0008,
        camd3: UserDB(update): USER=benutzer110 PASS=password10 FROM=any SERVICES=1702:000000:0008,1722:000000:0008,
        camd3: KeyDB: started
        camd3: HTTP: Address already in use
        camd3: rom120.bin -> No such file or directory
        camd3: CMD 02 -> 1801:003911:0041:056B from 127.0.0.1 ( camd3 )
        camd3: camd v3.900 b1 - erfolgreich gestartet
        camd3: start ecm pid 056b caid 1801 ident 000000
        camd3: start emm pid 0090 caid 1801 ident 000000
        Please help
        <--superchipper added 54 Minutes and 37 Seconds later...-->
        and with CCcam i got
        CCcam: nagra2 emu can't decode ecm (key: 1, ident: 3911)
        CCcam: cam[0] ecm odd nok caid:0x1801 id:0x3911 pid:0xa7b NET
        Last edited by superchipper; 16 September, 2008, 18:49. Reason: Automerged Doublepost
        • wall5
          Supperchipper, alguma novidade? Tambem sou novo e gostaria de sua ajuda. Thanks
          • eddlko
            • Jul 2010
            • 20
            how to check which version is my firmware
