EROR1 : NO CA FOUND how to fix
  • tony19652002
    • Sep 2009
    • 16
    DM800 EROR1 : NO CA FOUND how to fix
    EROR1 : NO CA FOUND how to fix the problem
    this is how to fix your error no ca found problem,this has been tried and tested and works everytime 100%
    this has happend beacause you didnt load a bootloader to start with.
    1st load up dreamup (the lasted version) then in the programe you will find extras,click on that it should say recover bad sectors,connect your dreambox up and press connect on dreamup,unplug your dreambox when dreamup is ready then plug back in your dreambox,now this is the important part....when the line on dreamup is about 25% unplug your dreambox...disconnect from dreamup and then plug back in your dreambox and hey it will then give you your dreambox isp on the dreambox display..now connect your lan cable in..then on your browser on your p.c..type in what the dreambox has told you (the dreambox isp) then on the bottom of the the page when it has connected you should have somthing like flash update..click on that..select nabliosat black hole (pached) it should load to your dreambox in about 5 or so mins,then once 100% unplug your dreambox and then plug it back in..and then every tim you swich of your dreambox or unplug it back in..you will have no more troubles.
    i hope this has helped
    best regards
  • vmitri
    • Jul 2010
    hello
    did everything you have said, after 25sec i disconnect the dreambox, it shows my ip on the small screen, after loading i put the ip in browser and i receive a "dreambox web control" with no flash upgrade???
    dont know what to do next, after reboating again the same error no ca found appers, i tried to plug power while pressing the power bottom with no help.
    please help something missing here
