FAILURE OF TRANSFER OF KEYS AND ROMS
  • gingerninja
    • 168
    HI THERE I AM TRYING TO GET PREMIUM CHANNELS AND WHEN I DROP AND DRAG FILES THE MESSAGE IS TRANSFER FAILED
    PLEASE ADVISE
  • portbhoy
    • 717
    You got to browse to the files right click and transfer
    • gingerninja
      • 168
      THE FILES ARE STILL NOT TRANSFERING
      ANY ADVICE
      • bugaloo41
        • 1598
        what are you using to transfer - flash fxp?
        • gingerninja
          • 168
          YES I AM USING FLASH
          • portbhoy
            • 717
            Do you definately have a connection? Only reason I can think of that the files wont transfer.
            • krazylegz
              • 2834
              double check you have a connection as stated by portbhoy and try to restart box, if still no good you might need to reflash
              and turn off caps lock, looks like your shouting m8
              PS3= krazylegz120282
              • gingerninja
                • 168
                cheers i shall try that later
                <--davidward999 added 179 Minutes and 5 Seconds later...-->
                hi there sorry just wonted to get further information for later.
                how do you mean if i am connected. i shall try and explain as simple as poss,please bear with us as i am a little green at this. The dreambox files come up and the pc establishes a connection. i then drag and drop or transfer as instructed and then a number of messages in green appear and finally a message in red says transfer failed.
                any further info please
                Last edited by gingerninja; 16 September, 2008, 12:16. Reason: Automerged Doublepost
                • rickets
                  • 135
                  get internet-soft's ftp commander and try again. add a server (your box using root and dreambox as username and password)
                  If you can't copy files on try copying some off and see what happens.
                  You might have no space left or a locked image and have thus to reflash as said above.
                  • Donnie Darko
                    • 442
                    As said further up,can you actually connect to the box?once connected you should see in the righthand window the entire file content of the db.If not you aint connected.
                    Checkout the RED stickies massive amount of info and effort been put into them.
                    • gingerninja
                      • 168
                      hi yes all the files come up from dream box and have downloaded new flash. still file is not transfer. i am trying fxp
                      <--davidward999 added 13 Minutes and 39 Seconds later...-->
                      hi there just tried ftp and message is saying host not found (winsock error #11001
                      please advise
                      Last edited by gingerninja; 16 September, 2008, 18:29. Reason: Automerged Doublepost
