Editing Read Only files
  • ronlkh
    • 74
    Hi All,
    I have followed the instruction of devilfish on the forum, I have got the image done but when I try this command as devilfish instruction:
    cd /tmp && eraseall /dev/mtd/5 && cp mtd5.img /dev/mtd/5 && reboot
    Done.
    The box erase well but did not seem to flash the new image, Can anyone please let me know what have I done wrong?
  • satman
    • 736
    Originally posted by ronlkh
    Hi All,
    Done.
    are you sure your mtd5.img is squashfs properlly?,
    and have you tried dd command to write the .img to the /dev?
    boom!
    • ronlkh
      • 74
      This is what I followed :-
      mkdir /var/tmp/root
      mount -t squashfs -o ro /dev/mtdblock/5 /var/tmp/root
      cd /var/tmp
      tar -cf root.tar root
      FTP the root.tar to your linux desktop and open a terminal.
      cd Desktop
      tar -xf root.tar
      Leave the terminal window open.
      Treat the root folder on the desktop as the box itself but don't add or do anything to /var or /var_init because that's still on the box.
      When you have finished go back to the terminal window and...
      ./mksquashfs root mtd5.img -be
      Then ftp the mtd5.img back to the box. You will need a copy of mksquashfs on the Desktop to be able to perform this command.
      Telnet back to the box and...
      Done.
      To check what mtd# ...
      more /proc/mtd
      ...but most squashfs are mtd5.
      <--ronlkh added 24 Minutes and 42 Seconds later...-->
      By the way I am using fedora 9 on VMware.Should I use debian or ubuntu?
      • satman
        • 736
        Yes, i know, i can see the tutorial you followed.
        So you managed to follow that right to the end and the mtd doesnt write?
        instead of cp mtd5,img > /dev/mtd5
        try a dd if=mtd5.img of=/dev/mtd5,
        another way is just slightly different from the tutorial would be to mount the root onto a hard drive or mount point as a loop device, read/write, and then dd backup, and then restore it over the current one with the dd restore.
        but both methods should work fine.
        boom!
        • ronlkh
          • 74
          i think the image made from mksquash dont work. I am not sure if it flashes the box or not but when it reboot, it got blue screen only. I tried many ways. I copy the root to my ubuntu and mksquashfs it and straight away ftp back to dm500 and flash the image back to dm500 and it also faill even i did not do any modification.
          how can I use the dd command? if the image is in the /tmp, should I just type dd if=mtd5.img of=/dev/mtd/5
          <--ronlkh added 17 Minutes and 34 Seconds later...-->
          Hi satman,
          When I tried using your recommended dd command, it says no space left on device
