Network wizard on my dream box
  • jerrell
    • 24
    Please help?
    When trying to flash FXP connection failed (connection lost keeps coming up
    How do I run the the network wizard on my box to see what Ip adress it gives, I know this sounds daft. But I have been going at this for 2 days now.
    Please note in network connections DHCP is turned on
    Thanks in adavance
  • smirnoff_rules
    • 8603
    have u put the passwords and log in in the ftp program
    root
    dreambox
    • jerrell
      • 24
      Thanks smirnoff_rules for the prompt reply, yes I have done that about 40 times today & yesterday
      • smirnoff_rules
        • 8603
        when l flash my dreamboxes l always have the null cable and internet cable inserted and click network in dreamup and turn off firewall too
        • jerrell
          • 24
          ok,
          my null & network cable are plugged to the box
          I am trying to use flash FXP to get the Magic files VAr Keys & Scce
          I am able to use dream up to Flash the new DK 1.1 image that works fine, but I do not have all the channels I had before when I had the DW 2.0
          • smirnoff_rules
            • 8603
            http://www.digital-kaos.co.uk/forums...e-power-99321/ l only use this ftp program now its the best and easier that any other l have tried
            • jerrell
              • 24
              Thanks for the FTP client but the same thing happens
              connection error conection timed out
              • smirnoff_rules
                • 8603
                ?? if your ip is right and u have the login and password the right way around this just works , lm not sure where u r going wrong m8
                • Fergal
                  • Aug 2008
                  • 1007
                  Did you get the ip of the dreambox and put it in flashfxp
                  Go to menu on your dreambox, scroll to setup then scroll down to expert setup,then communication setup, theres your dream box ip
                  • jerrell
                    • 24
                    Sorry had loads of trouble getting back on system kept throwing me off. (I hope I have not upset anyone)
                    Fergal I have done all that as I explained to Smirnoff, The last question to Smirnoff was as follows
                    Jerrell: i'm real sorry but how do i find a new ip. Do i just reboot my box after enabling DCHP and a new ip address pops up?
                    Smirnoff: yea use dchp first and reboot and find a new ip and use that
                    Everytime I reboot the box on the tv it comes up with the same ip address as per your instruction
                    I obviously according to smirnoff need to assign a new ip address
                    Sorry, I am not sure how find a new ip for my dreambox?
                    Please advise?
                    • smirnoff_rules
                      • 8603
                      Please advise?
                      u can turn dchp off if u want but if its on it will find one thats no being use . ie a laptop or something .. goto menu > settings > network and the one need to put in ftp is there . l sure u have tried that . l always have my box connected to the router , how r u connected to the pc ?
                      • jerrell
                        • 24
                        as we speak my null cable is connected from my dream box to my pc and my internet cable runs from my router to my dreambox
                        I have as per earlier use box ip followed by root followed by dream box
                        • jerrell
                          • 24
                          Smirnoff, i note you put the following goto menu > settings > network. I have menu setting expert set up communications and ip address is there,
                          Is that what you mean
                          • Fergal
                            • Aug 2008
                            • 1007
                            You dont need your nullmodem cable connected just the ethernet cable from dm to router will do
                            you use your wireless laptop connection to connect to your dreambox via your wireless router
                            password is dreambox not dream box
                            thats the ip you put in flashfxp or whatever ftp program you are using.
                            • jerrell
                              • 24
                              As we speak i have disconnected my null cable.
                              I always type it as dreambox not dream box
                              as earlier i have done this 40 times already
                              How do i assign a new ip address to my dreambox
                              as there is not a network wizard in network manger settings on the box to setone up
