500C Bad Flash Problem
  • Damien_III
    • 14
    Hi guys, I am so impressed with the 500C I bought another 2 for my bedroom and the kids bedroom. I managed to flash one box no problem, copied the keys and other files over and had it up and running in about 20 - 30 mins.
    The other box was not so easy, I set the flash away left the room for 2 mins and when I came back it had failed halfway through copying the image over. So I turned the the box off and restarted the PC and tried the flash again, this time it loads the boot loader but gets no responce from the box when waiting for acknowledgement.
    I have tried leaving everything including the PC off for 10-15mins before tring again but with no luck. Is there anything I can do to fix this or is it now a brick?
    I am using dream up version 1.3.2.1
    and tring to upload dk v1.1
  • smirnoff_rules
    • 8603
    try turning the off at the plug and back on fast why dreamup is search for the box ..
    if u just bought 2 more boxes l would thing u havnt heard of the new n3 code virgin or using around the country then ?
    • Damien_III
      • 14
      Yeah I herd about it, do you know when they will cover the whole of the uk? I thought I would take the gamble anyway. I will try the quick switching it off and on techneque tomorrow. Thanks for the quick reply.
        Sooner rather than later m8. Cards are in the post now.
        • Damien_III
          • 14
          I tried quickly switching the box off and on during the waiting for acknowledgement message but unfortunately that did not seem to work. Strangely the box boots to the original enigma setup fine so the box seems to be working fine it just wont flash. Anyone got any suggestions what I can try next?
          • kakabahra
            • Apr 2009
            • 4
            hi am new to dreambox please can u advise me on how to flash these boxes so all channels will work
            • cgscott
              • 3513
              All the info is in the red stickies http://www.digital-kaos.co.uk/forums...ox-dreamup-33/
              Use a null modem cable and a program called dreamup.
              Patience is a virtue.
              • kakabahra
                • Apr 2009
                • 4
                does it have to be a null cable or can i use rs32
                • Damien_III
                  • 14
                  I can FTP into the box so can this be done manualy?
                  kakabahra
                  It has to be a null cable.
                  • Damien_III
                    • 14
                    All sorted. I did a telnet flash instead of using dreamup and it worked like a charm. My null cable must be broken. Thanks to Devilfish for this tutorial guide-flash-backup-image-via-telnet.
                    • bob114
                      • 192
                      hi
                      from you post damien
                      now use the guide to back up the image and save on pc
                      then you have a working image you can flash if needed
