pli-jade scanning
  • napster
    • 53
    pli-jade scanning
    got a scanning issue with jade when i do a scan (virgin 6952)
    when scan is complite and you go into all channels by pressing OK then red button its pulled in two of every channel all have epg but only one works, is there anyway to fix this.
    cheers
    napster
  • gezz
    • 46
    Only time I've seen this is when the box has already been scanned before in different area. Was it the first scan after you put the image on?
    • Devilfish
      Administrator
      • Feb 2008
      • 7872
      Yeh that's the only time I've seen that, scanned on ntl then scanned on tw. But usually there's only one epg.
      Obviously a factory reset would cure it but then you'd need to do your bouquets again so it's not ideal. You could go through each channel and delete one of each. Or use DreamboxEdit to delete one channel and then transfer back to the box.
      • .: JaCkPoT :.
        Retired Sat TV Addict
        • Aug 2008
        • 5607
        The most time saving way is to delete 1 of each rather than rescanning then reapplying the bouquets.
        ___________________
        In the good old days, I had
        DM800s HD
        Openbox S10
        TM500
        DM500s
        90cm FortecStar dish
        Maxx 110cm Dish
        Technomate 2300 Motors
        • mrdude
          • 110
          The easiest way to do it is just to back up the cables folder - NOT the services and Bouquet files, Inside the Cables folder you have your user Bouquets - That's All you need to save.
          Then remove all the channels and reload the services & bouquets (like when you do a factory reset), Then do a full scan and ftp your backup user Bouquets - then reload the services and Bouquets.
          That way it will only take you a couple of minutes - rather than having to remove each channel 1 by 1.
          Suck my plums
          • napster
            • 53
            thanks for your replies but have done this removed service, box rebooted nothing on there, put my service's back on and everything is on till i scan, then i get double again, and im scanning the same option every time virgin 6952.
            jade image on a 600c
            cheers
            napster
            • fishy123
              • 64
              i have same problem m8 pli jade on 600 with 6952 scanning
              • Curious123
                • 2591
                I find that ocaasionally one or two channels in my bouquets don't have picture and if I look in the 'all services' bouquets there is the same channels with a picture so I swap it out in my bouquets. I think it is probably due to transponder changes if its new add it to your bouquets if it is not than just ignore it. On my sat box I have got half dozen Channel 4 and they all have picture.
                • mrdude
                  • 110
                  DONT put your services or bouquets files back on the box m8, that's why you're getting double - Just put your user bouquets from the cables folder. That way when you rescan you'll only get the channels found - and your new channels will be in the user bouquets you saved and put back on the box
                  Suck my plums
                  • napster
                    • 53
                    so all i need is these files from this location /etc/enigma/cable/ do i have to reload them or just reboot box after ftp them across
                    cheers
                    napster
                    • tfspark
                      • 25
                      I had this problem on a DM800.
                      Scanned in one area and set up, then scanned in a different area and had duplicate channels.
                      It was cured by doing a rescan but in the scanning options set "Clear before scan" to yes.
                      • napster
                        • 53
                        do we have this option is jade image for dreambox 600c
                        cheers
                        napster
