Another recording question
  • southpaw83
    • 360
    For the DK 1.1 image. Can you only record with Ngrab by setting the timer in the epg? When you press the green button, then radio it doesn't record with ngrab and i'd like it to. Is this possible?
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    The green then radio combination is for direct recording, ngrab is a plugin so I guess you need to use the timer. I've never used ngrab so can't really offer any more help on the subject, sorry.
    • southpaw83
      • 360
      Thanks, it's not really an issue, just wondering. Cheers once more
      • atrixo
        • 5
        Another way to record is by using Tuxvision. This will record the stream that you are watching. You should be able record Radio aswel.
        The best method and the one with the smoothest playback i have found is Ngrab.
        Direct recording is convienent but you will get missing frames on the recording.
        • dedge_10
          • 46
          ngrab
          i hope we can do a stop/start direct recording if dk release a new updated image in time just tried timer setup with ngrab and works fine Cool
