New Dreambox Edit
  • Parisno
    • 80
    New Dreambox Edit
    The version I got off here is an older one, don't know if this is of any use to any-one, but here you go!
  • RiverTrent
    What's different from version 2?
    • Neil
      • 194
      It works with newer Enigma 2 boxes correctly
      500c, 600c, 7025+cc, 7000s with a 1m steerable dish
      • Parisno
        • 80
        From Google
        "Support added for version 4 lamedb. Lamedb version 4 is used by Enigma2 images using drivers after august 2008
        Support for HDTV services. In the Advanced pane of DreamBoxEdit Options you can add HDTV services to be treat as TV-channels
        New logo by Litemotiv
        A number of small enhancements in the functioning of DreamBoxEdit
        Tips with the 7025/800:
        In DreamBoxEdit you must specify the correct paths on the 7025/800.
        You can do this very easy with the "Version 3 Settings(enigma2)" and "New Enigma2 settings" buttons on the options panel.
        New lamedb version 4 is chosen with the "New Enigma2 settings" button.
        You have to enable "Multibouquet" on settings menu in the actual 7025/800 Dreambox in order to be able to see your bouquets
        Known bugs in version 3.00.00:
        Translation problem with Satcodx files: servicenames with special characters are not correctly translated (but can be editted by hand of cour"
