dm500c ethernet problem
  • bob114
    • 192
    hi
    flashed image with dream up after setting ip adress on dm500c
    lost ethernet connection during flashing now have no ethernet connection
    tried 2 cables on different pcs no go still no connection
    internet sign on toolbar says cable not pluged in
    used cables on other boxes ok
    is the ethernet port an easy fix (ie could it have blown a fuse)
    thanks for any help
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    You don't need an ethernet cable when flashing with dreamup, you can use a null modem cable on it's own.
    Does your box boot up fully? If so, check the ip address hasn't changed. Some images have DHCP enabled by default so your router will have assigned it another ip address.
    • bob114
      • 192
      hi
      thanks for the reply
      just got 2 dm500cs from dvb seller connection problem started when changing image
      had set ip address ok before flash
      the box has flashed ok
      have tried changing ip address turned dhcp off
      connection crossed out on pc so carn't ftp
      used cable and pc on different box ok
      on second box tried to back up image with dream up
      got this log
      09:14:27 box type: DM500
      09:14:46 Ping result: OK, box is alive and speaking to us ;-)
      09:15:49 downloading image from box...
      09:16:03 ERROR while downloading image from box!!
      09:16:03 Error while creating Backup
      09:16:23 Ping result: NOT OK!!!
      I have not changed image on second box yet
      still have connected with ethernet port
      (just to say don't use router)
      just thinking may have 2 bad doxes
      • Curious123
        • 2591
        On your second box, leaving aside trying to back it up. Does the box connect to your home network and internet? Just need to establish if the problem is with your ethernet port, image or router?
        • bob114
          • 192
          hi
          yes at the moment 2nd box has connection (don't use router)
          loses connection when tring to back up image with dream up
          have seen files on box wih ftp program also had telnet connection
          because ethernet connection stops when using dream have not flashed
          box incase I lose ethernet connection all together like on 1st box
          (flahing works ok with dream up just carn't ftp so not able to add or save files)
          just to say before flash on 1st box had connection changed ip address
          • Curious123
            • 2591
            How are you connecting to your box to ftp files? With a crossover or a null modem cable?
            • bob114
              • 192
              hi
              crossover cable ethernet port on dreambox 1 is the problem carn't get a connection
              null modem cable connction no problem as box has flashed with dream up
              • Curious123
                • 2591
                I have had problems in the past connecting pc with crossover cables and other devices. It could be your pc and crossover cable configuration. It seems strange that both of your boxes have the same problem. If you have any friends with a router maybe you should try it there before considering returning the box.
                • bob114
                  • 192
                  hi
                  from my 1st post
                  BOX 1 the port stopped working through and has not worked since flashing with dream up (tried different ip address etc) connections all working fine on dbox and other dreambox
                  BOX 2 has erthernet connection stopped when tring to back up image on box
                  as log in post one (so have not flashed in case it goes same as box 1)
                  so realy asking is ethernet port easy fix as don't want to open box if needs sending back
                  thanks again
                  • Curious123
                    • 2591
                    The ethernet port connections are soldered onto the motherboard so there is not much you can do about it.
                    • bob114
                      • 192
                      hi
                      I have the box working (no ethernet connection)so will try flashing second box see what happens
                      thanks again for all replies
                      • bob114
                        • 192
                        hi
                        just noticed in a dream up tut
                        Make sure ?use network? is unchecked
                        I had it checked could this have caused problem as
                        ethernet port was working before flash
                        also will try backing up image on 2nd box again
                        with networkun checked
                        • Donnie Darko
                          • 442
                          Worse case you could probably solder in a new port
                          Checkout the RED stickies massive amount of info and effort been put into them.
                          • Curious123
                            • 2591
                            As your second box is partially working fine I would forget about dreamup and making a backup or flashing an image but rather concentrate on trying to figure out why you cannot ftp files etc.
                            • bob114
                              • 192
                              hi
                              the story so far on 2nd box used dream up with network is unchecked
                              backed up image to pc
                              then was able to ftp files to image
                              flashed working image and ethernet working ok
                              so if anybody has just got a new dm500c from dvbseller
                              make sure ?use network? is unchecked or you may not
                              be able to make a back up or even like me end up with no
                              ethernet connection (like box 1)
                              hope this may help
                              again thanks for all the help
