Cant get any channel even FTA
  • alithegreat
    • 59
    Hi
    My area isnt down yet, I live in Woking and havent recieved and new card
    After the channels disappeared, I did a bruteforce scan and found a lot of channels but none of them work even BBc doesnt work
    Plz help me
    Could be that your image has become corrupt. Reflash it.
    • alithegreat
      • 59
      But it was working before the frequencies were changed
      is it really the image problem
      • smoggie
        • 863
        go to all services, if there are 2 bbc two's select one of them and see if channel clears, if not try the second one to see if it clears
        • alithegreat
          • 59
          Well i havent got two bbcs, i have got about 15, all same channels. But thats not the problem, i am getting a no service message even on bbc
          • smoggie
            • 863
            well have you tried what i said on all the bbc2's then??go on each one individually and leave for a min and see if it clears
            • alithegreat
              • 59
              thnx it worked but I am not getting sky sports 1, 3, and 4
              They are the only reason i bought dreambox, what shall i do
              • Sirus
                • 340
                Im having the same sorta prob... the -no service found- message on some chanls.. is this just a Frequency thing, Ive tried a Bruteforce scan and it fixed some but still missing most
                I may have missed something over the last few weeks as I only come here about once a week.. is there a new cable.xml file or something that will pick up the new freqs.. but then why do I still get the epg listings on the no service found chnls, it looks to me like a freq thing because the little freq status bar jumps about with errors.. but how do you fix it.. or can ir even be fixed
                And my other openmedia box upstairs with a DW image has exactly the same problems on the exact same chnls
                Off the top of my head the chnls Im missing are
                E4's, Filmfour's, SS4, ESPN usa, Racing UK, Disney chnls, and SM modern
                Was missing some Discovery ones but the bruteforce scan got them back which makes me think its a frequency change thing.. the scan itself seemed to replaced the saved discovery ones in the bouquet which is weird... because usually you need to delete the old ones and get the new found ones and save into the old ones place in the bouquet
                So what is the crack with this no service found shite
                EDIT: just had a look over some other posts and... is this in any way linked with the 3.7 software thing?.... but then how is it possible to get some of the chnls back
                • smoggie
                  • 863
                  try removing all splitters etc, so that you have a direct feed to your box and then rescan
                  • Sirus
                    • 340
                    I dont use any splitters smoggie, I have two separate feeds in my house one for the living room and one for the bedroom
                    I even removed one of the plugs from the cable and cut a fresh piece of wire to see if it made any difference.. but didnt
                    I cant understand why the epg would still come through, even in the info bar but it says "service is not available" on the screen and signal info is SNR-50 AGC-99 BER-6522800
                    And just for the record, one of m SCiFi chnls is down with the message, but it wasnt last night.. goes like that all the time now.. weird
