should dreamup still pick box up
  • san1310
    • 6
    hi i have a dreambox under bed for about 5 month bought it last time boxes went down i pluged it in got an ip addy from it then when i went to flash it stopped working seller vanished so no cash bk i have been trying dreamup to try a nd reflash it myself but i cant get box to connect to it i know everything is ok null modem eg as i have another dreambox that i can connect np is my box dead or can it be fixed
  • alliv
    • 299
    is it a clone ?
    is it a bird?......is it a plane?.....NO ITS MY CHEAP CLONE FROM CHINA GOING OUT THE ~~~~ING WINDOW.
    • san1310
      • 6
      i think it is most likely to be a clone as i bought boxed last time boxes went down
      • Donnie Darko
        • 442
        Deffo using a null modem cable?
        Checkout the RED stickies massive amount of info and effort been put into them.
        • cgscott
          • 3513
          try a couple diffrent versions of dreamup. Also try diffrent com ports if you have that option in dreamup.
          have seen people with this problem before.
          although one person that contacted me had flashed the box with gemini image and could not get a connection to the box.
          Let us know how you get on.
          Patience is a virtue.
          • alliv
            • 299
            have you unticked use network? are you useing a laptop and usb adapter as theese give trouble with vista.
            • Ballistic
              • Oct 2008
              • 243
              Hi There,
              I am also having trouble with dreamup ( or maybe myself ) I have tried a couple of different dreamup downloads as suggested.
              I follow the instructions to the letter, using windows xp with null com cable in com port only one on lappy . It coms up as com 3 in dreamup ...I get to where it says turn dreambox on and i do then it just sits there doing nowt....
              Any help gratefully recieved.
              Cheers
              B
              "Racing is life... everything before and after is just waiting." Steve McQueen as Michael Delaney in 'Le Mans'sigpic
              • cgscott
                • 3513
                Does it register the model of the box then hang?
                • Ballistic
                  • Oct 2008
                  • 243
                  Hiya thanks for responding...
                  No it just sits there as if waiting for box to be turned on, i guess it should say at bottom left what model?
                  • cgscott
                    • 3513
                    Yes it usually comes up the model before its powered up. well with my dm500 it does. Then ones you power up it acknowleges the box then pings it and says it is talking to the box.
                    U sure it defo a null modem cable you got?
                    • Ballistic
                      • Oct 2008
                      • 243
                      Yeah sure as its the same one I use to plug the pc into a car ecu although i had to get an adapter 15pin to 9 pin to make it fit...would this cause a proble do you think?
                      B
                      • cgscott
                        • 3513
                        Most probably dead then. What images were flashed to it before?
                        • Ballistic
                          • Oct 2008
                          • 243
                          Just got it today so as it comes... Its a monitor connection at back of laptop so 15 pin female and the DB is 9 pin male so got an adapter for the pc end ..guess it maybe that that is causing the problem?
                          IS there a usb cable that has a 9 pin female that you know of...
                          Cheers
                          B
                          • cgscott
                            • 3513
                            try this
                            USB to RS232 Serial Null Modem Cable COM DB 9 Pin Lead on eBay, also, Other Cables, Cables Connectors, Computing (end time 26-Oct-08 10:08:42 GMT)
                            • Ballistic
                              • Oct 2008
                              • 243
                              Cheers that one has a 9 pin male which is the same as the back of the DM so wont fit, will have a search for a female one sure they do them.
                              I have also been looking in my device manager and cant find any com ports in there at all so may also be the problem...The port on the back of the pc has monitor image next to it so must be ok i would have thought?
                              Thanks for the help
