hi guys i know the 500 can be flashed with telenet but can the 600 be flashed this way too or is there a fast way to flash the 600?
can the 600 be flashed with telnet?
Try this m8;
Telnet to your dreambox and than type in
mount /boot -o remount,rw
rm /boot/*
rebootLast edited by Curious123; 5 October, 2008, 17:19. -
I've just needed the same info, and found you need a little more info than about, also provided by Curious123....
Log into box via telnet.
Type:
mount -o remount,rw /boot
rm -f /boot/*
reboot
Open up a web browser and type in the ip address of your dreambox (which will be one it picks up via DHCP not the one you had set in the config). This should take you to a web page. Choose the upgrade option and point to where you have an image stored.
Before you do this you must:
Make sure you have a reasonable way to pick up the Dreambox via DHCP once you've nuked the image.
Have an NFI image to flash
Have a machine to connect to the Dreambox web interface with that can see the Dreambox over the network (this is where you'll flash from)Comment
Sorry alliv I forgot about the web interface, I use the telnet bit to kill the bootloader and than use web browser to flash the new image. I use this all the time on my dm600 otherwise it would take at least half an hour using dreamup.Comment
thanks curious m8 , thats what i wanted to know. its a pain in the h@le waiting 30 mins.
is it a bird?......is it a plane?.....NO ITS MY CHEAP CLONE FROM CHINA GOING OUT THE ~~~~ING WINDOW.Comment
You either need to connect to a router, or directly to your PC. If connecting to your PC you'll need to use a crossover network cable as opposed to a normal one.
The easiest way is to connect to the router, then login to your router's admin web page and look to see what ip address it has assigned the box.Last edited by uczmeg; 1 January, 2009, 18:46.Comment
cheers for the reply m8.You either need to connect to a router, or directly to your PC. If connecting to your PC you'll need to use a crossover network cable as opposed to a normal one.
The easiest way is to connect to the router, then login to your router's admin web page and look to see what ip address it has assigned the box.is it a bird?......is it a plane?.....NO ITS MY CHEAP CLONE FROM CHINA GOING OUT THE ~~~~ING WINDOW.Comment
I have always given my dreamboxes a static ip address so I always know what it is for logging into the box.Comment
