No help for my DM900-C
This topic is closed.
channel disabled
hi there..in my dm900-cii when i click the yellow button then press confiq and under display settings theres a word called channel and its disabled..may i know how to enable it back?when i try scrolling its not scrolling..may i know how to enable it back..i think because of that my channels are not displayed..pls some1 help me..thanks alotComment
900
Hi jasmine that word channel under display setting is to programme the box to what channel you want to appear when you on tv set and your box.You can scroll to the channel and change to preview channel or disable by pressing the left and right botton on your remote. If you choose disable means when you last watch example channel animal planet than you off your box,than next you on the box again.Automaticly the box will display animal planet channel as last time you watch.
Now you said my channel are not display means?When you change channel theres no number or channel name display?Or theres no other channel other than FTA channel?If that the case than get yourself a new aucard as your aucard has expired. Theres no change of code currently.My advise get yourself DM500C it cardless.
Hi! Just got my DM900C 2 months ago. At first, most channels can watch, after 2 months, more & more channels says" No Signal", even the local channels like ch 5 & ch 8 also cannot watch. Is it time to change the card? or there are something i can do? I understand for 500C, it is cardless. Does that means even the cable TV opeartor change the encryption, it still can watch all channel? pls advice as im newbies here. Thks a lot!Hi jasmine that word channel under display setting is to programme the box to what channel you want to appear when you on tv set and your box.You can scroll to the channel and change to preview channel or disable by pressing the left and right botton on your remote. If you choose disable means when you last watch example channel animal planet than you off your box,than next you on the box again.Automaticly the box will display animal planet channel as last time you watch.
Now you said my channel are not display means?When you change channel theres no number or channel name display?Or theres no other channel other than FTA channel?If that the case than get yourself a new aucard as your aucard has expired. Theres no change of code currently.My advise get yourself DM500C it cardless.Comment
Hi Bro! May i know yours is DM900C-II or C-V? Mine is C-V. my problem is some channels still can watch while some channels got no signal( even local ch 5 & 8, U, etc.). My card is Nagra type. Pls advice.
Thks!Comment
900
If even FTA channel are gone,i suspect your box are faulty or tuner spoil. Yes DM500C if install with auto key update you dont need card, and yes if operator change code this file will auto detect and copy again cheers,the file works like magic.Hope this help.
Hi! Just got my DM900C 2 months ago. At first, most channels can watch, after 2 months, more & more channels says" No Signal", even the local channels like ch 5 & ch 8 also cannot watch. Is it time to change the card? or there are something i can do? I understand for 500C, it is cardless. Does that means even the cable TV opeartor change the encryption, it still can watch all channel? pls advice as im newbies here. Thks a lot!Comment
900
Your card has expired.Get new card or updrade to dm500c cardless.
Hi,
My box is Dream 900C-V too. Only today cannot view all the channels except Local Sg Free channels a d a pathetic SCV ch856 (but all my channels are still preset as the old version Scv channels)
It is still working well yesterday. Suddenly all blackout today.
Can someone advise me as I really do not how to solve the problem as this set is given by my uncle.
Card is Nagra Vision.
Any kind souls, please help me!!!!
Thank you!!Comment
