dm500c problems
  • mrred666
    • 5
    dm500c problems
    Just received my DM500c from DVBmonkey. The IR sensor on the DM500c does not function correctly i have to place the remote directly in front of the box about 10cm for it to work also the power supply blown just after 1 hour of use.
    I am using a universal power supply to get the DM500 running again but any ideas how to get the IR working.
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    If you bought a TV from comet and it didn't work properly, what would you do? Try and fix it yourself?
    Why not contact dvbmonkey and get a replacement?
    Most likely, the IR ribbon cable has come loose during transit. Remove the lid (being careful not to damage the hologram) and reseat the ribbon cable and try again. The fact that the psu has died means I'd be seeking a replacement.
    • dctyper
      • 2539
      psu is common, have you tried replacing the batteries in the remote - the weaker they are the closer you need to be
      Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
      previous life dm800hd and 500c on cable screw you nag3
      • harry1986
        • 516
        Try replacing the battery if that dont work then you got a fault so just tell Dvb Monkey and return it to them for a replacement just like Devilfish said and then wait for your replacement.
        • mrred666
          • 5
          The remote has new batteries I dont want to send the DM500 back to Dvbmonkey as it took 2 weeks to arrive. I had a look inside the DM500 and the ribbon cable from the board to IR module is all seated. Maybe Dvbmonkey can send me a new IR module as it looks easy to replace.
          • khan
            • 46
            hi mate
            u can check if the remote is sending signal by using your mobile phone.
            switch your mobile phone as if you r making video.
            when u press a key you should c the light flash in ur mobile screen.
            • mrred666
              • 5
              Happy
              Got a reply from DVBMonkey. I am very happy with their support as you can see why:
              Our customer support team personnel has replied to your support request #812787
              Thanks for your offering me the problem descriptions in details. The replacement IR module and power will be sent to you as soon as possible.We send you the whole front panel system including the IR module so you needn\'t do much and simple to assemble it.
              Thanks for your order and trust us.
              Logistics Returns & Development
              DVBmonkey.com
              We hope this response has sufficiently answered your questions. If not, please do not send another email. Instead, reply to this email or login to your account for a complete archive of all your support request and responses.
