Problems with my DM500T !
  • tmontana
    • Jul 2026
    DM500 Problems with my DM500T !
    Hey everyone, i just found this forum, what a fantastic resource for dreamboxes. Well heres my situation. i have a dreambox dm500T with the old DW1.65 image on it that has been working perfectly for the last 2 years. the other night at around 1am, picture started freezing and i noticed the signal strength dropped down to around 10% and i lost picture, so i went to bed and left it.
    the next day i powered back on and the signal strength is jumping from between 10% upto 96% continuously, so i have picture for a minute, then when signal drops pictuire goes,
    i have checked all cables are tight, i have replaced power inserter with a new one, i have changed cams,
    does anybody know what could be causing my problem, i left it for 3 days thinking that the bad weather may be causing the signal to drop right down, but its still the same
    does anybody have any ideas?
    Alan
  • cgscott
    • 3513
    Could be the tuner inside your box mate.
    try installing a different image and see if that makes any odds.
    If not try a signal booster. Then assume that it is an internal problem.
    Find out from anyone local to you with same box/image if they are having any problems.
    Patience is a virtue.
    • tmontana
      thanks for the reply mate,
      do you know of any other images that will work on a 500T?
      • Fano
        • 331
        Sounds like a faulty downconverter to me.
        Have seen this happen a few times.
        Did you try a different receiver to see if that works ok ,it would isolate the problem area for you ?
        If you dont have a spare receiver you could run the cable into the back of the tv and check the analogue reception to see if its ok and not ghosting.
        • tmontana
          thanks for the reply fano mate
          i had thought it might be the down converter, but i have no way of changing this as its up on my roof
          im going to try a new image later today and see if that works, if it doesnt it must be a faulty tuner or the down converter as you suggested because i fitted a brand new power inserter already
          i wasnt aware that we could get analogue T.V in Ch**us MMDS area?
          • Fano
            • 331
            I doubt a new image will make any difference.
            Yes you can get around 3 unencrypted analogue channels on Chorus MMDS,Sky One,Sky News and TV3 just do an automatic scan on your tv.
            • tmontana
              ok ill try scan for channels later
              Fano, i have sent you PM
