hi
don't know if it was just a coincidence used dream up on a dm 500c
from dvbseller with use network ticked now ethernet port does not work
on seconed box unticked use network box when using dream up
etherner port works ok
i have used dreamup with a 500c box from dvb monkey and its working fine. Dreamup is not a image an image is gemini dk image etc dreamup is a flash programe like flashfxp
Thanks for quick replies everyone - sorry got a little bit confused as not using DM500C yet - still the clarified issue and confirmed that Gemini image should be avoided. Is it just 1 particular version of Gemini that is a killer or is it all Gemini images
