Dreambox 500c,not opening channels!!!
  • mojo25
    • 24
    Hi to you all,
    flashed dreambox with dk_v1 as well as dk_v1.1,using Dresmup & Null serial cable.Then downloaded the Dreambox Keys off Rapidshare & did the Transfer using Flash FXP from PC to The Box which Showed all the keys being transfered,following the instruction on the forum.
    I shut down down the Box & restarted & went to sky sport 1,waited to clear.
    still no picture came up.
    I wonder, if I have to change Evocam 2.12 OR Change the Digital choas to Enigma at all.Any suggestion or help will be much appriciated!!
  • cgscott
    • 3513
    CAn take anyhting from a minute to 2 minutes to clear. If you have followed the instructions it should be working fine.
    Must be patient.
    Try again.
    Patience is a virtue.
    • mojo25
      • 24
      Hi there,waited more than 5-6 minutes,still no joy!!
      • cgscott
        • 3513
        Then youve done something wrong somewhere mate.
        Try holding info for a few seconds the cam menu will come up restart the cam and see what happens.
        Doesnt need to be SS1 you try i usually have mines on bravo after an install.
        See what happens mate. Let us know.
        • mojo25
          • 24
          cam menu starts ok,but I just try Bravo channel,as well.
          • mojo25
            • 24
            Sorry,still no luck on Bravo!!
            • mojo25
              • 24
              Must go to work.will post this tomorrow,as well.
              Many thanks
