Dreambox500c,FTA's only!!!
  • mojo25
    • 24
    Hi to you all,
    flashed dreambox with dk_v1 as well as dk_v1.1,using Dresmup & Null serial cable.Then downloaded the Dreambox Keys off Rapidshare & did the Transfer using Flash FXP from PC to The Box which Showed all the keys being transfered,following the instruction on the forum.
    I shut down down the Box & restarted & went to sky sport 1,waited to clear for more than 5-6 minutes.
    still no picture came up.
    I wonder, if I have to change Evocam 2.12 OR Change the Digital choas to Enigma at all.Any suggestion or help will be much appriciated!!
  • westkill
    • 2378
    there should be an option to restart evocam try that
    • mojo25
      • 24
      hi there,re-started the evocam 2.12 okay,& holding the key down which showed it started,but no still no picture!!
      • mojo25
        • 24
        I wonder,IF I have to use dreamup to erase & flash the dk_v1,& repeat whole process again??
        • thered
          • Aug 2008
          • 4915
          did you put keys in var/keys and scce in var/scce or put them in together
          • aftermath
            • 4345
            you need to put in the roms , these will be in folder scce and go to var/scce folder on box.
            • mojo25
              • 24
              Yea,I put the keys in Var/keys & scce.I don 't think I put them together,but I run it on FXP again to see how it goes.
              Many thaks
              • mojo25
                • 24
                So,It means,I put the keys into scce folder first & then open the Var/scce afterwards?
                • cgscott
                  • 3513
                  No it means when you ftp the box drag the whole folder over to var/scce
                  Same with the var/keys
                  Copy whatevers in the folder.
                  If it asks you to overwrite then do so.
                  Patience is a virtue.
                  • funkyarshad
                    • 8
                    thx for the info
                    • altyguy1
                      • 34
                      500c
                      goto sky sport1 and hold the info key for a min then it will come on,,
                      hope this ok for you,
