Hi,
I'm having some issues recording from my DM500. I've read as many of the stickies as I can but still have a few questions.
Here is my Setup:
DM500 using DW 2.0.
Laptop is sucessfully connected directly to DM500 ((100mb) using network crossover cable - no router.
Laptop Shared folder is sucessfully mounted on DM500.
Here is my problem:
I can record using the remote ("Radio" Button to start, "TV" to stop etc...) and it seems to work fine but when I playback either on the Dm500 or even using VLC on the laptop the images are pixelated every couple of seconds.
Some times, on different recorded programs, the pixelation is is only every few minutes - on other programes its so bad it unwatchable.
I'm just wondering if anyone has any suggestions for me ?
Are there any specific settings I should be using ? What are the best values for the rsize and wsize settings ? - what do these mean ? are there other settings I could try ?
Also, Could someone explain the difference between the way I am recording above and and if I were to record using Ngrab installed on the PC - whats the difference and whats the advantage/disadvantage.
Also, has anyone spotted what appears to be a bug in the Web-x-tv interface in the <Config>, <mounts> section where it appears to get the mounted drives all mixed up and shows several settings for drives that are not mounted ? is there any fix to this.
Here is my Setup:
DM500 using DW 2.0.
Here is my problem:
also will get a looot of useful stuff for ur box if u connect it to the internet such as cams,addons...all directly downloaded to ur box.
