Evocamd for pli flubber?
  • kitoog
    hello there
    I am having problems with a few channels using a dreambox clone. the only images which seem to work fine are the older non max var images. I installed pli flubber but the download server on it does not work. is it possible to update the pli download server on flubber? or does anyone have evocamd which will work with a manual install?
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    Which recevier do you have?
    • kitoog
      sorry,should have said it is a 500c clone. or do you know is it possible to edit the download server on flubber so I can download it through the box?
      • Curious123
        • 2591
        Pli Flubber for the Dm500C is a really old image which is probably why you cannot get the download server to work.You want the Pli Iolite or their latest image called Pli Jade.
        • kitoog
          i know its an old image but scanning is alot better if I use old images like gemini 3.0 . i think these may be non max var images. well anyway the scanning is a lot better than any of the newer images. there is one channels which either stops after a few seconds or is totally out of sync if they do work. i have tried nearly all images possible but no fix yet. its not a signal problem as all other channels on the same transponder are fine.
