6 way splitter ok?
  • corky_croydon
    • Oct 2008
    • 32
    6 way splitter ok?
    Hi, I just bought a 6 way splitter from B&Q as they had no 2 way ones left.
    Will this be ok still? I only want 2 outputs.
    just wondered if it decreases the signal having 6 outputs even though i'm only connecting 2.
    Cheers
  • cgscott
    • 3513
    Will be fine. The signal will only weaken as per how many recievers are attached to the splitter.
    Patience is a virtue.
    • corky_croydon
      • Oct 2008
      • 32
      thank you!
      • Dazzonamission
        • 174
        Cheers
        Unfortunately you will still suffer some signal loss,try get your hands on some 75ohm caps to screw onto the unused ports, signal will leak out of the un-terminated ports.
        or better still get yourself a two way splitter,splitters are great in one respect and a nightmare in many others,they increase attenuation and un-terminated ports cause higher SNR.
        • caveman_nige
          • Feb 2008
          • 4920
          Very interesting info, I will try and remember that as I have some caps (in a bag somehwere not on the spiltter) but never saw why they would be used other than to stop the end getting dirty or damaged etc..
          • corky_croydon
            • Oct 2008
            • 32
            Hey, I used the 6 way and it worked fine, Good signal strength etc. Thanks for the info though!
