help with usb to com
  • jake1970
    • 135
    hi i hope some one can help me ,i had to reistall xp on my pc but when i try to reinstall dream up it wont install and i get the error message ,error cant find any com ports , ive been using the usb to com port adapter and had no problems using it with dream up before and i dont think it came with any driver disks (atleast i dont remember installing any drivers for it before.
    dreambox 500c
  • jbvid
    • 261
    Hi
    These adaptors can be a pain in the a*s* under normal conditions but as you don't have an install disc it will be impossible. You could look in device manager to see if any ports are listed, but those will likely be the ones that XP installed by default. If its only a one off flash your doing goto a m8's PC with a 9pin port. Alternatives, google for drivers or buy a PCI Plugin type with 9 pin out com port, these are far better and not much dearer, popular auction site.
    jbvid
    • portbhoy
      • 717
      Download file and run, take cable out first. When the file has finished running insert cable and hardware wizard will come up let it search automatically for the best driver.
      Sorry lads the zip file wont work from here follow the linky Digital Kaos
      • jake1970
        • 135
        thanks im installing now
        dreambox 500c
        • jbvid
          • 261
          Hi portboy
          Nice find, will treasure for future similar problem posts
          jbvid
          • jake1970
            • 135
            im installing but nothing is happening and then i plug usb to com adapter in and i still get the error when installing dream up
            dreambox 500c
            • jake1970
              • 135
              still not working ,im installing huge pine but nothing happens ,this is very frustrating as i now it was working fine before i reinstalled xp
              dreambox 500c
              • portbhoy
                • 717
                If you got nothing when you plugged in the USB adapter then that suggests there is something wrong with the USB port you should have got the hardware wizard, if you dd and it's not finding the device then uninstal the hugepine adapter and try this one USB to Serial Adapter driver downloads and documentation
                • portbhoy
                  • 717
                  Originally posted by jbvid
                  Hi portboy
                  jbvid
                  No problem for future refrence if you have a USB to serial adapter that looks like the one below then chances are this one will work.
                  • jbvid
                    • 261
                    @portbhoy
                    Hi
                    Not sure if its my end but I get corrupted file after trying to unzip the driver, maybe this is the problem with jake.
                    jbvid
                    • portbhoy
                      • 717
                      Sorry mate it wont rn the zip file from here follow the link http://www.digital-kaos.co.uk/forums...d=384&act=down
                      • jbvid
                        • 261
                        @portbhoy
                        The link works fine, thanks
                        jbvid
                        • mastermac
                          change setting
                          i had to change the com port setting in device manager
                          so that i was using com port 2 for the usb 2 serial
                          Has it sometimes sets it to 5 and above
                          making it so that the program can't access it
                          i hope this is of some use
                          mastermac
                          • harveybham
                            cheers i;ll try that as well
                            • espresso
                              I hope this works for me too, have the same troubles to get it to work..
