D500C OR D500S
  • harry1986
    • 516
    D500C OR D500S
    D500C OR D500S Which of these boxes give you more channels cable or sat?
  • Curious123
    • 2591
    The DM500S gives you about a 100 times as many channels as cable but I remember how much trouble you had with cable so I would seriously research your box before you go out and buy a satellite box.
    • mad irish-man
      • Oct 2008
      • 23
      Hi there harry
      A mutlitude of answers here.I believe cable gives you the most choices of channels as saterlitte is not completely cracked. Sayinig that, if you have a valid s*y uk subscription card then the choice may differ. I maybe wrong.
      M.I.M
      • harry1986
        • 516
        Curious123 ive picked up alot since then and i know what to do now was a newbe back then just saying to ask members which picks up more channels sat or cable?
        • Curious123
          • 2591
          Harry m8 I have seen some of your posts since you got your cable sorted and realise you have learnt a lot but satellite is a completely different kettle of fish even for experienced cable users. I have cable and satellite in my house and if I really wanted to I could probably now do without cable altogather but the wife finds the remote for the sat too complicated so I have not bothered to remove cable. Just advising you to proceed with caution rather than trying to dissuade you from following into the satellite scene.
          • .: JaCkPoT :.
            Retired Sat TV Addict
            • 5611
            The satellite scene is more experimental. With cable you have a set amount of channels which all open but on satellites you get new sats,channels,new encryptions, new packages, hacks and headaches.
            Now make your choice. I found cable boring. Its not for experimenters. My sat box is doing the best.
            ___________________
            In the good old days, I had
            DM800s HD
            Openbox S10
            TM500
            DM500s
            90cm FortecStar dish
            Maxx 110cm Dish
            Technomate 2300 Motors
            • harry1986
              • 516
              thanks for your help i wonder what other members think whats the best
              • loncell
                • 625
                as people have explained to a sat set up , there's alot more to it than a straight forward flash box and scan.it all depends what you trying to watch.setting up a satelite system is not for the faint hearted especially a motorised system.
                i tried to set up a motorised system and ended up calling out a sat fitter to sort it out.
                when all said and done i would ask yourself this ;- what extra channels or which stations do i wanna pick up ? this will determine of you need a cable or sat set up.
                money wise a cable 500c is roughly ?80 a sat set up is double then if you dont know how then a satman to install which could be anything form ?50 to ?100 .it took me roughly 6 month to get to grips with a dm7020 on a motoised set up so bare that in mind.
                • westkill
                  • 2378
                  if you got time on your hands , give it ago m8
                  hardest part for me was putting the dishup , cause i live on the 5th floor
                  • Curious123
                    • 2591
                    Have to agree with Westkill, the toughest part is getting your dish installed. Without the proper alignment on the dish you are just flogging a dead horse. I have got my dish at the bottom of the garden on top of a 6 foot scaffolding pole.
                    • jbvid
                      • 261
                      @harry1986
                      Hi : DM500S
                      Sadiq999uk has put it in a nut shell, Sat has a lot more available channels, but you really need to know which encryptions are hacked and
                      which Satellites the hacked channels are on. Then decide if its for you.
                      Google 'Lyngsat' for Sat listings and encryptions.
                      jbvid
                      • harry1986
                        • 516
                        i got sky box with freesat at the moment but want extra channels to watch than cable ok just say i wanted to watch alpha punjabi how would i get it hacked to watch.
                        • westkill
                          • 2378
                          curious that was a pain the arse to line upi was sat on the handrail of the balcony in the end with a compass pointing it southwith the remote in the other hand pointinting it through the window to scan 1w
                          then tightend those nuts up and it worked
                          if i had a garden i would have a 3m dish
                          • Curious123
                            • 2591
                            This is a bit off topic but I remember your dish hanging out of the balcony so thought you might like to see how mine was set up until about 3 months ago.
                            • westkill
                              • 2378
                              what size ladder did you use
                              was it a small skirting board ladder
                              i like the way you weighed it down with bill and bens flower pot
                              does the job though m8
