600 image
  • Bonesy
    • 655
    600 image
    Guys, working on 600 here now. flash jade but it wont connect to their server to get the emu etc..etc..
    Never worked with jade before and doing my head in and in rush to sort for friend.
    So anyone have a good 600 image backup including all the *cough* files, then can send me please via email or link?
    Please pm me if you can thanks once again.
  • thered
    • 4915
    just telnet the cams to the box they are ipk files
    ipkg install /tmp/INSERTCAMNAMEHERE*.ipk
    first ftp the cam to temp then use this command put cam name make sure it is spelt correctly then restart the box cam will then be in the image
    • Bonesy
      • 655
      thanks for the info.
      Im just finishing flashing the box using dreamup now. With jade image.
      I can ftp to the box, not used telnet much, so what I need to do next?
      • Bonesy
        • 655
        Nope no matter what I do the jade pli image (latest version) will not connect to the server to download stuff
        • thered
          • 4915
          install manually through ftp and telnet
          • Bonesy
            • 655
            I have many 500 and setup those ok, but this new 600 just will not talk to net to download, emus etc...when its meant too.
            And I will also need the Bouquests, sorted, which is a pain, so if anyone has a backup image they could email me..I would be endebted
            • thered
              • 4915
              right i have you connected the box to net properly have you changed the network settings on the image to work with the pc
              have you got a crossover cable to connect to pc
              at the end of the day i havent got a 600 so i cant spoonfeed you an image to use someone might but i cant
              but at the end of the day you will need to learn how to do this with your image or you will be ~~~~ed next time the roms need changing anyways
              so the best bet is to learn how to configure your box
              you need dcc or flash xp and a crossover cable to transfer files manually from pc to box if you havent got them you will be ~~~~ed unless someone gives you their image
              • smoggie
                • 863
                It took me 3-4 to get my 600 sorted, but was worth the effort in the end.when downloading from PLI i ended up connecting the box to router as I could not get it connecting with the box straight to modem. read some of the threads i posted as i'm sure there will be info there for. I also had trouble FTPing the cam over which is why i persisted with trying to download from the server. Also make sure you put in cable xml file from here http://www.digital-kaos.co.uk/forums...k-ireland-243/
                • Curious123
                  • 2591
                  You need to tell us how you are connected to the network and also show what you have in your network setup configuration. So far all you are doing is telling us you can't connect to the download server.
