EPG Timer keeps defaulting to Ngrab
  • bub
    • Aug 2008
    • 55
    Hi, I would really appreciate some help on this, when selecting something to record through EPG on my 600pvr the setting on Timers keeps defaulting to 'Ngrab' instead of 'Record PVR' because of me sometimes not noticing this then the program wont record. It will only record if I change the setting to 'Record PVR', is there anything I can do so that the timers deafaults to 'Record PVR' I have taken a pic so you can see what I mean
    bub
  • bub
    • Aug 2008
    • 55
    Anyone have a solution to this, would be really appreciated
    • bub
      • Aug 2008
      • 55
      Because of this the wifes recording of Im a celebrity didnt work as she forgot to change the Ngrab setting, she wasnt too happy
      Come on guys 57 views and not one reply doesnt anyone know how to make the Timer Edit Screen default to 'Record PVR'
      bub
      • osborne82
        Dreambox Guru
        • 133
        bub
        when setting the timer through the epg press yellow and it should defalut to pvr if u press green it defaults to ngrab
        cheers
        osborne82
        • bub
          • Aug 2008
          • 55
          Excellent cheers for reply,mine works a bit different, it seems if I am in EPG mode and I want to select something to record, if I press the Green it will go to 'Record PVR' mode, if I press yellow to record the program it will go to 'Ngrab' so there isnt really any default, you just select Green or Yellow from EPG mode to get into the record mode that suits you.
          Wouldnt have discovered this without your help Osborne
          cheers
          bub
