Dreambox 500c help
  • HyperTurtle
    • Apr 2010
    • 7
    DM500 Dreambox 500c help
    My dreambox has just stopped working. When it's turned on the tv switches to ext1 (the tv source for the dreambox) but nothing appears on screen apart from the blue screen, any help will be appreciated.
    Have you tried different scart leads ?
    • the man
      • 1660
      its your 1st post, do you understand about n3?
      • HyperTurtle
        • Apr 2010
        • 7
        The scart lead doesn't seem to be the problem, but I see your logic.
        If it helps I think the problem is due to switching the box off while the image was being flashed (using flashimage from the dreambox menu, but it froze so I turned it off). In regards to n3 I didn't know about but have looked it up and can't see how it applies to this situation
          In that case m8 reflash the box again, use dreamup it takes about 10-15 mins to reflash.
          • HyperTurtle
            • Apr 2010
            • 7
            Thats what I thought; I don't have a null modem cable atm. so thought I'd ask to see if there was any alternative i.e. a master reset or something. Thanks anyway
              No m8, the only way now after a bad flash is to reflash using a null modem and dreamup
