you may have created more problems than solved m8, if its a bad flash you,ll need a null modem cable and dreamup software to rescue the box.
it will flash a new image to the box safely, i always use the null lead to send images to mine, it takes longer but is safer and you can rescue it if it goes tits up.
hopefully you already have a null modem cable at home, if so plug it in your pc and box and use dreamup software to send the image to the box.
for people who are not into telnet and fxp it is the easiest way to go.
start software select com port1 click connect, plug box in(power) then flash image, simple no going wrong but it takes a bit longer than the other ways.
well i had the 600 working on cli image and wanted to try a different one ,dreamup would not flash. [useing laptop / vista and comport converter ] so i thaught i,d do it as you suggested with telenet. ie
mount -o remount,rw /boot
rm -f /boot/*
reboot
used putty program to do this. i had ip set on the box and i could telenet to the box before this. after putting in the command mount -o remount,rw /boot
rm -f /boot/*
reboot the box went off and came on with red light flashinrg and the odd green flashing light every now and again. now i.m stuck,any idea,s m8? thanks for the reply.also tried restarting the box with power button held down , still no joy.???????
__________________
is it a bird?......is it a plane?.....NO ITS MY CHEAP CLONE FROM CHINA GOING OUT THE ~~~~ING WINDOW.
I am doing a friend a favour by trying to get his DBox up and running, and wondering do the telnet commands that are detailed on this thread work on a dbox.
I have been using this method for my 500c and have never had a problem, so I was hoping I could flash a image using this telnet method for the DBox.
Also I know it is doubtful, but is it possible to flash DK1 image on a DBox or is this image specific to dreambox
my box won't allow you to click on to flash as it is greyed out.. what am i doing wrong...?
followed your instructions to the letter and my box is useless now,i've only a green light on the front,nothing else but a black screen,no menu's or welcome screen,channels or anything,any ideas?????????how can i rescue this now?????????????
Having problems with Dreambox tools v3
When I run universal dreamup I get an error "there is something alive with IP 192.168.xxx.xxx in your network that is not a dreambox. Dreamup may not work properly"
i renamed the image wrong when i ftped it - i typed in the command and it got as far as erasing but stopped when it couldn't find a matching image file
i then repeated the command and get the error message:
"cp: unable to open '/dev.mt/3': no such file or directory"
what should i do?
edit:
nevermind i restarted my telnet client and redid the commands - which seems to have done the job
rm -f /boot/*
reboot
rm -f /boot/*
__________________
n osx
Ok first time poster here but this looks like you erased your boot loader very smilar command in osx rm -rf / will delete every thing /boot would this not be the bootloader use jtag to reprogram ?
