Got the above after a flash and now it wont boot or communicate over serial cable, the box meeds a master reset, anybody any ideas how to do it.
hmmm tricky one... So you are unable to flash erase? Not sure what to try next has been so long since i had too do mine.... I take it its a clone box, which image did flash it with?
Thanks guys tried both but still wont communicate with dreamup nor can you telnet to it, guess its a real failure, asked "dream multimedia" for support on this but they say same thing, load new image.
I have read elsewhere that leaving the power out overnight and then trying to reflash the folowing day works, i can't vouch for this method but i guess you have nothing to loose..
Other guys will be coming online as the day goes by and another idea or two should be forthcoming.
thanks and if I get a response from Germany I will post it in case anybody else has this problem. I have left it overnight didnt make any difference.
later
You need a null modem cable, not a serial cable. They look the same, but the wiring is different. Try maplins.
definately. used it the day before on another dm600 no problem, gonna get it swapped this week, they believe it is a hardware fault
never mind it happens
