leave it as is the light is a nuisance anyway but on a more serious note you can check the led solder joints on the mainboard but you could do more damage than good.
If your willing to open your box with a screwdriver; follow the cable from the light to the main board. Here is where it is plugged in. It probably just needs a tap. Make sure the contacts are good. Other wise I'd try changing the LED but for this you will have to get your soldering iron out..
