Rom 11 card and dreambox
  • ashton3
    • 8
    Can anyone direct me how to get dream box 500c work with a rom 11 card It is being done im my country but i cant seem to get it work .I know pli helinite and newcamd softcam is installed but to get them to work is a problem. Can anyone help . thanks in advance.
  • 2tone
    • 483
    Have a look at this post m8 tells you how to get the dreambox to read the card and also if you want to set it up on a server in your house if you have two dreambox the othere can share of the main one any probs post here and im sure some one will help you out m8
    • ashton3
      • 8
      Thanks 2Tone as soon as i get back to the card I will try it and let you know. By the way can a rom card be written over? Thanks.
      • sherlock
        • 35
        This is revision dependant, but with unlooper yes, if you know its not locked just use nagra edit.
        Should you get the rom card workin then you also may be able to use fun card etc.
        • ashton3
          • 8
          Thanks sherlock. the card started to read but but then it says backdoor retrieval has been block that is why i ask if it can be written over.
          • ashton3
            • 8
            rom 11 card and dreambox.
            i have config the newcamd and the cardserve for my dreambox as was said and shown by 2tone.when i go to cardinfo all i se is retrieving cardinfo
            cardserver smartcard information. nothing else comes up.
            it does'nt seems to read the card. am i doing something wrong.
            • red devil
              • Oct 2008
              • 690
              edit the config file in newcamd on the nagra1 line that says boxkey to match that of your card or edit your card to match bk already there either will do and restart
