how to manualy update my dreambox
  • dman2080
    • 39
    hey guys. . ive been told i have to manualy update my keys
    im using the dk1.1 image
    ive got evocamd on .
    so the auto update doesnt seem to be working
    can someone explain to me how i manualy update my keys
  • Jaffa
    • 1612
    Have a look here m8.
    • dman2080
      • 39
      Originally posted by Jaffa
      thanks man . il check that out now ..
      so wil my box work with this or is it more of a chance to take ..
      ive read on here from anotehr v.i.p member that we mgiht have to wait for firmware which could take a whiel ??
      thanks again .
      • smirnoff_rules
        • 8603
        if u can ftp to your box this is how
        The format of the keys files are....
        If you are using evocamd, you need to edit the keylist.txt file.
        If you are using mgcamd, you need to edit the SoftCam.key file.
        If you are using gbox, you need to edit the nagra file.
        All these files are in /var/keys.
        Inside the key file, the format should be as follows...
        ex-tw
        N 5A01 00 1234567890ABCDEF ;
        N 5A01 01 1234567890ABCDEF ;
        ex-ntl
        N 5401 00 1234567890ABCDEF ;
        ex-c&w
        N 5C01 00 1234567890ABCDEF ;
        Replace the 1234567890ABCDEF with the actual keys.
        • dman2080
          • 39
          ex-tw
          ex-ntl
          ex-c&w
          thanks will give that ago also ..
          love this site ..you guys are always quick to reply ..
          thanks again .. ill let u lot know how it goes
          • smirnoff_rules
            • 8603
            u need to turn off the au (autoupdate ) and l cant remember that bit till l get home
            • Devilfish
              Administrator
              • Feb 2008
              • 7872
              Digital Kaos image is already set to only update the keys if the current keys are wrong so you won't need to change that.
              • smirnoff_rules
                • 8603
                any idea for the 600 l have ? cheers m8
                • Skiboy
                  • 151
                  smirnoff I've just done my 600c with the latest keys from keymaster..use dcc then the ftp proggie var/keys/keylist.txt right click edit change the keys then save..thats it m8.
                  cheers
                  • smirnoff_rules
                    • 8603
                    cheers
                    and no need to turn off au
                    • Skiboy
                      • 151
                      Sorry should have said m8, I have mine set to 02 on the au side.
                      cheers
