dream 500c and code input ?
  • bph
    • 48
    hi guys i have just got a dream 500c on wednesday and was in the process of setting it up when the s**t hit the fan so to speak.i have dk image on i think i have disabled autoupdate in var/keys folder by changing the { 2 } to { 0 }
    but i did not have any keys in my var/keys folder so i have put in
    N 5401 00 ************** ;
    N 5401 01 ************** ;
    latest codes and saved but no joy!!!!
    as i am new to this box any help will be great.
  • Jaffa
    • 1612
    If you have no keys in the keys folder then it doesnt matter what you do, it wont work. Are you saying the keys folder is empty ???
    If so then you can get the files you need in the 1st post of the thread below, its a rapidshare file and it explains what you need to do with it in the 1st post.
    Then restart your box and then go edit the keylist.txt file.
    • Ballistic
      • Oct 2008
      • 243
      you have got the bit after the ; aswell i take it?
      B
      "Racing is life... everything before and after is just waiting." Steve McQueen as Michael Delaney in 'Le Mans'sigpic
      • bph
        • 48
        no nothing after the ; but when i rebooted the box and held down the info button the cam menu came up and i restarted the evocam and every thing ok now but i still would like to know how to edit key as when i use tuxcommander on tv i can not see how to edit key
        • Ballistic
          • Oct 2008
          • 243
          press blue button
          then button 3
          scroll down on left column to keylist.txt
          then press button 4
          should then highlight them select which line and press ok
          then you can move along and change.
          exit
          red to save
          exit
          red to save
          exit
          reboot
          HTH
          Also I see CG has put a guide up here http://www.digital-kaos.co.uk/forums...er-keys-13468/
          B
          • jckw
            • 760
            do i need any addons for kaos image 1.1 thanks guys
            we are all learning each day
            • Ballistic
              • Oct 2008
              • 243
              no I dont think so just the keymaster exe
              • Jaffa
                • 1612
                You don't need any plugins cos you can do it with tuxbox commander but there is a plugin to make it slightly easier.
                • bph
                  • 48
                  got that ballistic i had been opening the key file before pressing 4 cheers m8
                  • perkinini
                    • 32
                    hey guys i am having real great difficulty i have tried everythin with this box ive followed the guides to the letter and still no joy i really need help
                    • Jaffa
                      • 1612
                      Hi m8, we need more info from you.
                      what softcam are you using.
                      did you disable AU or set it to auto.
                      Was there any other keys
                      what area are you from ( there are some areas which have not had the keys updated corrctly in keymaster yet)
                      • loncell
                        • 625
                        Originally posted by Ballistic
                        press blue button
                        then button 3
                        then press button 4
                        exit
                        red to save
                        exit
                        red to save
                        exit
                        reboot
                        HTH
                        B
                        when i get to the "press 4 button" the box flashes but doesnt respond on screen ,,i've tried all the buttons but i cant highlight the keys to makes the changes .am i missing summut ?
                        • Jaffa
                          • 1612
                          When you scroll down to keylist...do not press enter, just highlight it and press 4, if you enter then press 4 nothing happens.
                          • bph
                            • 48
                            jaffa see post 5 then 9
                            • terry009
                              to disable autoupdate in var/keys you need to input 02
