dreambox doesnt start
  • bandwlipstick
    DM500 dreambox doesnt start
    I was trying to flash dm500-philps-boot.bin with dcc and my dreambox doesnt start anymore.
    I cant connect to my dreambox via lan because of IP problem (using crosover cable)
  • ezay
    • 53
    Hey How Did You Flash It Firstly? Via Ethernet & Ethernet Hub Or A CrossOver Cable? If so then you can revive the box with a NULL Modem Cable.
    You can get these from : Serial Null Modem 9-Pin Female to 9-Pin Female > Maplin
    • bandwlipstick
      It just doesnt start at all, when i turn on there is nothing on screen (blackscreen)
      i bought NULL Modem Cable and nothing works , maybe dream up is a problem is there any alternative for dreamup
      • Curious123
        • 2591
        Any lights on your dreambox when you switch it on in case it is an power adapter issue.
        • bandwlipstick
          Yes there is a green light and it doesnt change the color at all
          • firestorm
            • 1550
            I had a problem like this(just a greenlight) last year on a 500s could not get dreamup to work so i got an old pc with windows98 on it connected dreamup and it worked first time
            • kieran2604
              • 10
              use dreamup to flash an image to your box m8-had the same problem today. some idiot who thought hed make some money wreakin peoples boxes ended up coming back to me to try and fix .
              get the digitalworldz null modem image and use dreamup to flash it to your box and then use the nagrarom 7 fix and that should be you.
