DM500C Easy Manual Key Input !!
This topic is closed.
  • Dazzonamission
    • 174
    Firstly i would suggest you install the DK1.1 image as Devilfish as made it very easy to manually change keys with the DreamBox Key Editor Addon, This can be download directly from the DM500C if connected through a router.
    Once you have installed the DK1.1 image do a Transponder Scan for your area should only take a few minutes,
    Once the Transponder Scan is done, you need to add the plugin available on your DM500C via the DK1.1 image, Now press the Yellow Button and you will see Kaos Panel, select 2 Manager Suite, select Addon Manager then select Server DK Addons, then select Plugins,(Router Required) then select Dreambox Key Editor and press Blue button this will now install the Dreambox Key Editor..
    Now restart enigma by going to Menu, Shutdown, select Restart Enigma
    Once Enigma has been restarted click on the Blue Button and select
    Now you need to simply add the Key information aquired from the Keymaster update into the 2 input boxes.
    You will need your Provider Codes ie. 5A 01 TW ? 5C 01 C&W ? 54 01 Pure NTL ? 5E 01 Ireland NTL ? 5F 01 Chorus Ireland.
    This example is for TW
    N 5A01 0123456789101112131415
    Once the provider ID and Keys have been correctly installed, press update..,Go to sky sports 1 and then press and hold the info button for a few seconds, EMU page will open, select evocamd2.13 and wait for it to start.
    Channels should return within seconds.
    Hope this helps people who are not familier with inputting keys into the DM500C
  • ticticboom
    • 125
    yeah good post dev couldnt make it any easier for us its like hes in all our homes sorting us out that how easy he is tryin 2 make the cable scene for us 2 understand
    • Jimbob10
      • 16
      Dazz,
      All sorted mate,
      Thanks for the help on this your a STAR !!!!!
      • Dazzonamission
        • 174
        Originally posted by Jimbob10
        Dazz,
        All sorted mate,
        Hi Pleased you got it sorted m8, We got there in the end....
        Devilfish has simplified the whole process now with Dreambox Key Editor Addon, Which i am sure will make it much much easier than having to do it via the tuxbox commander.
        I just want to say Thank You for Devilfish for what has to be the most User friendly and approachable forum in the UK.
        Devilfish is the real STAR !!!!!
        We just help provide additional support through our own experiences.
        Best of Luck.
        Dazzonamission
        • richlcm
          • 6
          Is there a way to check the provider code? I'm not sure where to aquire the provider code.
          • despdan
            • 544
            Originally posted by richlcm
            Is there a way to check the provider code? I'm from Singapore.
            Hi richicm
            try one of the images i pm you. I know they work in singapore
            • kasser134
              hey guys need help setting up dm500c.
              installed gemini 4.10. dont know how or where to install keys or cam.
              Please help cant view premium channels.
              Thank you
              • despdan
                • 544
                Thank you
                Try reading the stickies at the top of the page first they have all the info.
                But to get you started.
                press blue button>add ons>download from gemini.
                download evocamd & mgcamd.
                then you need to get the latest fixes try google thechatterbox.
                • blowfishcable
                  • 6
                  Hi Guys, i still cannot download the newbies guide, please help
                    Give the server time to update m8. Should be ok in about 10 minutes or so.
                    • Oogster
                      Tried the dreambox editor as I can't get the autoupdate to work.
                      Am using digital worldz v 2.1 image and it has the dreambox editor plugin. Got correct keys for my area from chatterbox keymaster and uploaded to the box.
                      (I could only get letters to go in in lower case - does this matter?) Succesfully updated the keys folder as I checked via tuffbox. Keys are there but still can't get channels. I tried rebooting box, and restating enigma from the shutdown menu.
                      Went back to slysport1 - no picture. Tried holding info down - but no joy - just tells me what the program is that I ca't get a picture for. Feel like i'm really close to getting the dreambox back up and running after ages out. What am I doing wrong?
                      All hlp greatly appreciated. Cheers
                      • soros
                        • Mar 2009
                        • 13
                        Originally posted by despdan
                        Hi richicm
                        hi despdan, could i trouble you to pm me the image as well... or alternatively if you could point me in the right direction as to how to get this info, it would be most appreciated...
                        i am a complete newbie here so still reading nd trying to find out more.. and getting lost in the process!!!
                        • despdan
                          • 544
                          PM me your email
                          • rastaman
                            • Mar 2009
                            • 12
                            Hi richicm
                            Hi despdan, may i have the images too? i'm from Singapore and needed the key in order to use.
                            • despdan
                              • 544
                              Did you get your box set up yet?
                              You need to have the latest keys & roms folders loaded also install a cam or 2. then PM me your email.
