How to add new channels for DM 500-C II
  • kenngks
    • Oct 2010
    • 34
    Is it possible to add new channels just for the Frequency range started at 586MHz for DM 500-C II which is pre-loaded with S***Hub channels? How to do it?
    I had done a manual transponder scan with the following set up:
    1. Frequency : 586,
    2. Symbol Rate: 6875,
    3. Modulation QAM : 256
    It stated that there are 12 new TV channels found after scanning but I am not able to locate them. Only 10 channels were found after I did a manual count on my existing available channels in this set up box.
  • jiangou2007
    • Oct 2010
    • 37
    2 of those 12 found are there before u scanned.So total is still 12!
    • kenngks
      • Oct 2010
      • 34
      Do you mean there is not way to add that 2 new channels into the existing list to make it 12 channels in total?
      • khan
        • 46
        just a question what is a 500c II ?
        • angsana
          • 30
          those 2 "new" channels are already there before your scanned.
          • Arraysys
            • 173
            I also wonder what is DM 500-C II? Is that a Dreambox or .....
            • kevlinks
              • 152
              I think its the new black version??
              • kenngks
                • Oct 2010
                • 34
                It is a china made Dreambox which is pre-installed with SH channels software for Singxxxre market. I am not sure if this is a clone version of dreambox DM 500C.
                • kenngks
                  • Oct 2010
                  • 34
                  Then it should have shown as 0 new channel found if the 'new' channels are not infact a new one?
                  Back to the same question, Is it possible to add any new channels in the consolidated channels list for this particular model?
                  • Arraysys
                    • 173
                    You got picture of your box? Or simply describe how you add the channel? How does the appearance look like?
                    Because right now no one know your model.
                    • kenngks
                      • Oct 2010
                      • 34
                      I did a channels scan as described in floor 1. 12 new channels found but don't know where to find it.
                      Picture for this model as attached.
                      • jiangou2007
                        • Oct 2010
                        • 37
                        you try to re-scan that frequency that found 12 new channels.
                        it will still show 12 'new' channels found!!
                        understand?
                        • Arraysys
                          • 173
                          1. Frequency : 586,
                          The above Frequency 586MHz contain 1*Radio, 2*Data, 9*TV Channel make up total of 12. But I think on that box you can only see the 1*Radio & 9*TV.
                          If you are adding channels with other frequency range, I believe you can try the auto-search / NIT / manual search. Not so sure because I don't have the box but most of the ox support 3 type of search.
                          • kenngks
                            • Oct 2010
                            • 34
                            Thanks Arraysys. I think you are right. This explains why I can only find 10 channels after carried out a manual count on the available channels in my box for this frequency range.
                            I tried manual scan function, but I don't dare to do a auto scan or NIT scan because it may mess up my current channels numbering.
                            Is it usually that new channels will be auto added after a auto scanned was carried out in other similar dream box ?
