Iam trying to update my dreambox 500c with an new image with flashwizard pro and i get message image to big to install on memory and the image is dw 2.1 the new one any one can help.
I think you have to use Dreamup in the downloads section.Be very careful using Flash Wizard Pro,I flashed 2 boxes and they both went into a continous loops,I managed to recover 1 with Dreamup but the other one is ruined.Dreamup is much safer
Hi, i always use dreamup, its very very easy to use and safe. but you need nullmodem cable and i use also cross cable both. its take 5-7 min to upload image. and yes set up the ip adress correctly. i think all the info will be here in this forum. read b 4 you use it.
