new auto update rom 7 not working
  • boocay06
    • 30
    #16
    Originally posted by jake1970
    yer everything still ok here vm south east with au on
    jake, try going onto a ppv channel for a few seconds then try any of the other channels, because if it still works for you then ive done summin wrong
    • jake1970
      • 135
      #17
      i just checked went through all movie channels etc and xxx sports 1 all working fine
      dreambox 500c
      • gums
        • Oct 2008
        • 63
        #18
        Originally posted by badboy247
        I have a problem as well. FTPd my dreambox with the file list that devil fish so kindly put out as my keys and scce folders were empty. FTPd them all over. Check for the AU 02. Thats fine. Rebooted. Still not working any ideas.
        sounds like you've either done a fresh install and not copied the keys over or youve deleted all the contents somehow - you should have some files in one of the folders you should have the other 7roms.bin and in the other you should have the cfg files.
        if not download the rapidshare keys and place them in scce and keys folder, then get the new nagrarom7 and replace the old one.
        reboot and restart cam and you should be gtg.
        • gums
          • Oct 2008
          • 63
          #19
          had the same problem myself last night - had installed the fix and was flicking thru the channels and when ive turned it on this morning only FTA channels
          quick flick onto skysp1 and a reboot has sorted it, cheers devilfish.
          • badboy247
            • 52
            #20
            I didnt have any files in them. Dont know how i would of deleted them but looks like i have. Did download the rapidshare files and put them in correctly. Also did already replace the nagra7.bin file with the new one overwriting the one from rapidshare still no luck. will ry it again and see how it goes.
            • badboy247
              • 52
              #21
              another thing how do irestrt the cam?
              • gums
                • Oct 2008
                • 63
                #22
                hold info for 3+ secs to get cam menu, then restart cam
                dont forget to replace the nagrarom7.bin file after you have put all of the other keys and cfg files back on
                • badboy247
                  • 52
                  #23
                  I have done everything which was asked to do but still not working. Not even getting BBCone now.
                  • smoggie
                    • 863
                    #24
                    all okay for me now, restarted the box this morning and was working
                    • badboy247
                      • 52
                      #25
                      no keys are going into the Keylist. It is really bugging me now...
                      • gums
                        • Oct 2008
                        • 63
                        #26
                        hmmm strange as you should be at least getting some FTA services even if you didnt have the keys installed correctly.
                        you could try dreamup to reinstall the image again as if there's files been deleted from the scce and keys file, who knows where else things may have disappeared from
                        if it were me, id whack a new install of dk1.1 on thru dreamup, ftp the keys over from rapidshare, delete the 10 and 11 roms and then copy over the new nagrarom7.bin
                        reboot and restart the cam
                        also have u checked all cables etc?
                        • gums
                          • Oct 2008
                          • 63
                          #27
                          also make sure that camd_cfg line 19 is set to 02 - AU auto
                          • badboy247
                            • 52
                            #28
                            Yeah of course I have. Is there a guide on here on how to reinstall the image? Everything makes sense it is just so annoying that i cant get it to work
                            • badboy247
                              • 52
                              #29
                              yeah checked that as well
                              • gums
                                • Oct 2008
                                • 63
                                #30
                                alright mate chill out, just checking, sometimes its the simplest things
                                yes theres a guide on here just search
