I just get the DM900C-II on Oct now i cant see any channel, can somebody please pm me the code .... Really appreciated ")
Help with DM900c-ii
Wrong conception. If you know how to fix the card, you can program it NOT to expire. All it need is a 74HC244 for a ISP progger. Jatrophasee had post the .bin file and the dates are there for anyone to change.
Of course, Singaporeans are rich and wanted the convenience. Just buy a new card or even a new box.
Bro Micromouse knew that J'seed's files worked as I was told since 2007. As for the file of 8K and 512, any bin editor can rewrite the 1st to 5th generation crds.
6th Genreration cards, need a more advance USB progger. ^.^ ISP is disabled.
Guys, where can I get this USB progger? Got 3 sets of DM900cii, now all can't view. Tried to key in the keys, but still the same.Comment
Once I had explored the feasibility of programming myself as I much an adventurous technical gadget guy and had with few dozens of expired cards on-hand.Wrong conception. If you know how to fix the card, you can program it NOT to expire. All it need is a 74HC244 for a ISP progger. Jatrophasee had post the .bin file and the dates are there for anyone to change.
But the more i digged for this DIY thing, more disturbing info on "fuse lock", "fuse password", and "DIY customized circuits" from the forum, I finally ditched the idea.
I was wondering if those info was just a FUD dud info from card-mongers to keep their trade intact.
If someone had tried and success, appreciate if you could PM me your approach, your purchase inventory, I would like to emulate your success.Last edited by ultrakiasu; 1 March, 2011, 03:56.Comment
dear all,
i am changing my dm900 due to all this issue on expiry date, can you guys recommend which box i should get? dm500?
how much is it?Comment
Ya! Tought of changing to DM500C also. MIne is 900C-V. However, some channels still can watch, some cannot, it says"no signal", even ch 5 & 8 have no signal too! wonder whether is the card prob.
Anyone can advice?
Thks!Comment
when fta also no signal, 2 likely cause: a) bad cable, u need at least a proper cable point from provider. cable from wall to stb must be at least a rg59 coaxial cable.
b) dvb-c tuner unit is dead. return to seller for RMA.Comment
Hi Bro! Thanks for your advice! However,when i 1st got the set 2 mth ago, all channels works fine! it was now that this "no signal" prob occured. Then again, not all channels have this prob, some channels are still receiving good. So, it still could be the tuner prob? when i connect to my original STB, it works fine. really lost! Tot of changing to DM500C which is cardless but still worry the same prob will happen again. Pls advice.
Thks!Comment
From the wall cable pt to the box should not hv more than a 2way splitter and the cable must be RG6 or better. The splitter used must be less than 3db per split and dont use the cheapo 'T' splitter that they sell in cheapo shop.Hi Bro! Thanks for your advice! However,when i 1st got the set 2 mth ago, all channels works fine! it was now that this "no signal" prob occured. Then again, not all channels have this prob, some channels are still receiving good. So, it still could be the tuner prob? when i connect to my original STB, it works fine. really lost! Tot of changing to DM500C which is cardless but still worry the same prob will happen again. Pls advice.
Thks!Comment
900
Yes you can do that(receive and transmit)But have you check your card wether it has expired?
card
If you suddenly cant watch premium channel that is the sign.You may check with your friends,if their box working with their card. If theirs working,than slot your card in to your friend box,if not working than comfirm your card expired.
Another method theres special machine that can check card expiry date,but i dont think is neccessary to purchase unless you're into card business.
