Update with New rom7 stillblank screen
  • alyas786
    • 31
    DM500 Update with New rom7 stillblank screen
    i have updated with the new fix rom7 on DK image but still i am getting fta channels but no other channels at all need advice.
  • mark015
    • 254
    did u dealete the rom 10 and 11,u shud only have ur rom 7 files. did u restart ur cam also
    • Jaffa
      • 1612
      Did you delete all the 10 and 11 files in keys folder, that includes nagraram10/11, nagraepr10/11 and nagrarom10/11
      Also is the AU set to {02}
      • alyas786
        • 31
        yes i have now deleted the rom 10 and 11 and just added rom7 new fix but still no luck do need to reimage it and insert the rom into keys or scce in DK image
        wher do i find au settings.
        • mark015
          • 254
          did u restart ur cam try a reeboot of ur box..post 57 has all the rom 7 u need >>http://www.digital-kaos.co.uk/forums...13/index6.html
          • jfish
            • 799
            can you paste a copy of your camd_cfg file
            • MILLWALLFC
              • 173
              How many Rom files do you have after you add the new rom7 file you should have 3.
              • westkill
                • 2378
                there should be 3 in the scce folder
                nagraepr7.bin
                nagraram7.bin
                nagrarom7.bin
                • alyas786
                  • 31
                  ok i have done that from post 57 insertedted the keys and roms but stillblack wat am i doing wrong
                  • 2Fast2Hard
                    • 15
                    I had it working with rom7 update until just before a sporting event was to start at 4pm today screen locked up then.
                    Reset to fta.
                    Old TW area London. Suppose there are many the same.
                    Seems like a key change every day.
                    Have to check the forum and see if it just me. Not sure what the AU is set to but its a dk1.1 image so should be fine.
                    • westkill
                      • 2378
                      delete all the text out of the softcam and the keylist text file dont delete the file
                      did you reboot the box and resart the evocamd or mgcamd what ever your using
                      • jfish
                        • 799
                        Reset to fta.
                        check your AU settings in the camd_cfg
                        • eurohawk
                          • 33
                          d k1.1
                          i had the same prob could not get it to work, using dk 1.1 then i tried it on dw 2.1 imge works fine.
                          i deleted all the other roms as mentioned in the earlier posts, put the new rom 7 in restarted evo 2.12 still on hope it helps mine you i want it to work on my d.k 1.1
                          • Celtictiger
                            • 119
                            I am at a bit ofa loss, I am across the pond in Ireland and had not experienced the auto keyroll issues that was in the UK. for the last few days All that being said, I do not undersatnd the requirement to delete the nagrom.10bin and nagrom rom11 files?
                            • 2Fast2Hard
                              • 15
                              Done a delete of keylist.txt data in file so blank.
                              Reset box and its key list is now (key code) ROM11 AU key time Sun nov 11 22.39 for both set 00 and 01
                              evocam 2.12 on dk1.1 image
                              The AU is set 02
                              Still only fta.
                              will try rom 7 update again.
                              may need to use keys from keymaster?
                              Thanks for feed back.
