Help With Dreambox Edit
  • pawnhawk
    • 26
    Hi All, I am having problems with dreambox edit, and was hoping someone can put me on the right track.
    I have a dm600 and have reflashed, applied new fix and everything works ok.
    I start dreambox edit upload all services and bouquets, then I edit them into the order I want, then send them back to my dreambox. When I reboot my box everthing is just as I started, it will not update the files.
    It says the files have been sent and completed but still no change, any help would be appreciated.
    Is there any other software I could use to sort out channel order.
    Thanks.
    Pawnhawk
  • pawnhawk
    • 26
    Fixed the problem now. I used opendbedit, I know its the same as dreamboxedit or similar, but it's worked.
    Pawnhawk
    • mcassidy
      • 47
      Hi. I have had exactly the same problem but as yet have not found the solution. I followed Devilfish' s sticky on Bouquets and Services. I FTP'd to the Dreambox and deleted all the user Bouquets which had originally been created by the DK1.1 flash i.e "Terrestial", "Entertainment" etc. I replaced these with my own bouquets (copied from another box) However when I rebooted the box the old bouquets were still there. When I FTP'd to the box again the DK1.1 flash bouquets had reappeared!!. I was going to try and copy the content of my own bouquets into these but I have not had time to try it yet. I did start to try it manually using the Dreambox remote.
      Click OK. Press Red for "All Services". Highlight a Service. Press Menu. Select "add to Specific Bouquet." Navigate to the appropriate bouquet and add the service. This method is very tedious but it does work. The content of the bouquet is added and remains. I will do a little more investigation and if I find a solution I will post it on the forum.
      I will also try the Editor which you have suggested.
      • Mubz
        • 168
        on the option screen on DreamBoxEdit have you clicked on 'cable receiver' where it says 'reset Dreambox file path to their defaults for:'
        so the user bouquet file should read
        /var/tuxbox/config/enigma/cable/
        Mubz
        Growing old is inevitable, growing up is optional ...
