mpmaho2 you will need to reflash it again with dreamup and a null modem cable. That's the only way back.
Digitalwordz image 2.0 with Dbox 500c
try this, press blue button on your remote,(plugins). click on dw dream menu.. go to emu selection and press ok. press then red button on your remote to start evocamd wait for about 15 sec or so if nothing happen's press the green button mgcamd wait again and keep repeating untill signal clear's.. if nothing happens after a couple of mins your still using the old cable keysComment
hi
i just flashed my dreambox with this image but now i m not getting sky sports 1 and 3
the previous image i had used to work fine and had all these channels
but in that image i canot access the tuxbox comander to change the keys and i cant even ftp the keys as when i go to required file which is
var/keys/nagra roms/none when i click on none nothing happens
plzzzzzzzzzzzzzzzzz help me me i really want thes channelsComment
Sounds if my DM500C is dead as well. Done a factory reset and deleted all the keys. Tried manually putting in the keys. Now it wont even pick up a transponder during an auto scan. Trying now to hook up the box by ethernet to my cable modem to reflash. Dont know if it will work though?Comment
Flash it again using dreamup and a null modem cable. There's a guide at the top of the dreambox forum.
Take your time, don't rush it! Make sure you're doing the right thing and not skipping any steps. That applies to anything you do with the dreambox.
Trying to get it up and running ASAP will only get into more bother and you'll have to start again and again and again.
Flash the image, let it reboot, go to a premium channel, press BLUE then OK. The emu will stop and start and it will try to auto update the keys but they will be the wrong keys.
Then go in and edit the keylist.txt file with the latest keys, save and reboot.Comment
